Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Wheel and Tire (https://honda-tech.com/forums/wheel-tire-56/)
-   -   25mm wheel spacers (https://honda-tech.com/forums/wheel-tire-56/25mm-wheel-spacers-3299658/)
trav1985.tc@gma May 27, 2017 08:24 PM
25mm wheel spacers
I own a 2014 Honda Accord Coupe ex-l 3.5L v-6 and put on a set of 25mm wheel spacers on the rear and the sides are not even. My passanger side wheel comes out farther than my driver side. I jacked back up and removed wheels and checked spacers and everything looks normal. Drives fine but have no idea why one looks so much bigger.
https://cimg0.ibsrv.net/gimg/honda-t...8f7ee9781b.jpgPassenger side
https://cimg1.ibsrv.net/gimg/honda-t...f551def79a.jpgDrivers side
Turk@TireRack May 31, 2017 03:56 AM
Re: 25mm wheel spacers
That is strange... Are they factory wheels?
NVturbo Jun 1, 2017 03:16 AM
tires aren't even the same size. Was it that hard to realize that, OP?
Turk@TireRack Jun 1, 2017 05:47 AM
Now that I look closely, you're right- it looks like one is wider than the other....
OP, did you check the tire sizes?
RobRac Jun 15, 2017 10:31 PM
What are your wheels specs? Did you roll your fenders? Don't you experience any rubbing with 25mm added? Are you going to go wider with the front?
