08 factory alloys on a 2016?
i just picked up a 2016 honda fit lx for my daughter whos learning to drive. i want to add factory alloys to it. does anyone know if the 2008 fit alloys will fit without any issues? (i'm thinking caliper clearance) i realize the 2016 runs on 16 inch and the 08 would be 15 inch but the steelies are 15 inch right now. only reason is i want dedicated snows for her for this coming winter so i want to get a second set of rims. also, do the 08s have tire pressure monitoring?
Re: 08 factory alloys on a 2016?
the 2008 fit wheels should be 15x6 +55 offset with 4x100 pattern.
quick search for 2016 came up with this
Honda Fit 2016 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
shows the wheel as 16x6 +48 so a bit lower offset than 08. shouldnt be much of a problem. you may want to pull the oe wheel and check the specs to be sure
