You DIY your own crossmember/traction bar setup! post details/pics here
#401
Re: You DIY your own crossmember/traction bar setup! post details/pics here
disregard found them
http://www.ebay.com/sch/i.html?_nkw=...male&_osacat=0
now just need to figure out what soce i need.
the heim joint is listed as a 0.625 in. Bore. what size bolts are you gues using. will a 1.5" bolt have too much slack?
i guess i am just a dumbass. found my answer again. i am just scared of odrering the wrong parts again.
0.625 = 5/8
http://www.google.com/url?sa=t&rct=j...uu9sXzEt09FssQ
#402
ALright quick question people.
I drive a DA and i am wondering if its safe for me to remove the lower part of the radiator core now that i have a traction bar?
#405
Built this one a while back. Its still on the car and working just fine.
https://honda-tech.com/zerothread?id=1665396
#406
#407
Made this back in 11' for my friend's 87 Prelude. Ran out of oxygen and acetylene so I cut out all the plate with a 4.5" grinder. Had to shorten up the radius rods a little, but they're straight, and full pen welds. Also plug welded the bungs
#409
You know, I don't remember, lol. I fab'd so much stuff for that car it was hard to keep track of anything. It's up on stands right now since we're about to boost his F22b1 I shoehorned in there, so I'll grab some measurements for ya when I can
#410
Here's mine for the ol crx...
Cut the stock radius arms.
Spun them down in the lathe at work.
Welded the bung in the end of the tube for the heim and welded the tube to the rod. So far so good.
#412
Just discovered this thread and I have to say thank you to everyone that has contributed info to it. I'm in the process of building a traction bar to clear kiwi's splitter brackets on my racecar (89' crx). I was going to modify the stock crossmember but between the splitter brackets and the header not clearing I just decided to make something. I''ll post up a picture or two when I'm done if it doesn't look crap. Don't hold your breath on the pictures
#414
#415
Crazy Honda Guy
I'd be interested to buy a quality bar if someone is willing to fab one up for me?
#416
Sorry to bump an old thread..
but does anyone know where I can order the (2) end flanges for the lower radiator support bar?
And if not, what thickness steel plates to use? 1/4"? Rather buy some pre cut instead of making my own to save some time. Already made the traction bars, just need to finalize my lower radiator support bar.
Thanks in advance
Thanks in advance
#417
Thanks in advance
Thanks in advance
#418
SQ is the SQUAD
Welding / Fabrication
02-19-2007 06:03 AM
