Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Welding / Fabrication (https://honda-tech.com/forums/welding-fabrication-53/)
-   -   header difference??? (https://honda-tech.com/forums/welding-fabrication-53/header-difference-1055107/)
SHystrdyGSRtdy Nov 13, 2004 09:21 PM
since i know this is the welding section... you guys would pay particular attention to header details...
(if this i am wrong... please move this to the appropriate place.. TIA)
anyways... what is the difference between the jdm header and the US DC header (both being 4-1), anr's header, smsp's header etc.... BESIDES the collector size... specifically... are the US DC headers primaries not as long as the better headers (ie, smsp's, anr's, etc)
again.. TIA
RMF Nov 14, 2004 08:49 PM
Y
That quote ^ up there is some funny as shit
I having problem...........
Ekasey Nov 14, 2004 09:02 PM
Re: Y (RMF)
Long primaries are not necessarilly better
SHystrdyGSRtdy Nov 14, 2004 09:27 PM
Re: Y (eLusive ek4)
so what makes them expensive headers top notch? besides the quality aspect.. i'm speaking of a design stand point (for an n/a setup)
Ekasey Nov 14, 2004 11:12 PM
Re: Y (SHystrdyGSRtdy)
There are many things to be considered in designing a header for specic application
such as
Primary sizing
primary length
4:1 vrs tri Y
Collector sizing and angle
Tail pipe sizing
on and on etc a header designed to a partciular application is going to compliment that partciluar engine better then another header will
Example i designed a header for a top notch race team SCCA
They chnaged cams hafts built the header the gains showed 38+ hP from 2000-4000 and from 4000-8000 3-4 hp
I redesigned the header i redesigned the header with the new camshaft 2000-4000 gain was 3-4 4000-8000 = 15 + HP
shows how muhc a simle cam chnage can afftect the header designed
Occasionally you can get a good middle of the road header that will compliment a wide variety of engines but there is muhc more power to be gained from one designed for a specific combination
Doctor CorteZ Nov 16, 2004 12:01 PM
Re: header difference??? (SHystrdyGSRtdy)
with headers its obvious , you get what you pay for.
wrong forum also.
