diy filled b series block, with writeup, comments welcome
heres the deal. filling a stock sleeve block to handle mucho boost for under 50 dollars.
full info on devcon here http://www.devcon.com/techinfo/108.pdf the supplies. 1. DEVCON LIQUID ALUMINUM F-2 (1 lb ) for b series ( 3/4) lb for d series 2. BOX OF TABLE SALT. 3. 80 GRIT SAND PAPER. 4. CONTACT CLEANER 5. HACKSAW BLADE ( for measuring) 6. SHARPIE 7. 19MM WRENCH 8. FUNNEL 8 BEER ( optional) 10. LEVEL HERE ARE THE STEPS 1. gather all supplies, listed above. https://img.photobucket.com/albums/v...0/000_0692.jpg 2. put block on a level surface, make sure its level. if on a stand level the stand front to back and side to side. https://img.photobucket.com/albums/v...0/000_0688.jpg 3. take 80 grit sand paper and skuff the water jacket and sleeve so the devcon will bond when poured. after you sand it, spray with a contact cleaner to remove, oils, grit, ect. 4. take your hacksaw blade., this is your ghetto marking tool. place blade along sleeve where the water pump hole is. the end of the blade will be even with the top of the water pump hole. where the blade intersects with the deck draw a line. that will be your measurement as to how far up to fill your jacket with salt. 5.pour salt evenly around the jacket until it meets your measurement you determine with your hacksaw measuring stick. be sure to take the blade and poke the salt to remove ait pockets and have it sit uniform. https://img.photobucket.com/albums/v...0/000_0691.jpg 6. after the salt is air pocket free and to the level you desire., mix your epoxy. stir together for at least 4 minutes. after the mixture is a uniform grey color pour it through the funnel and into your jacket. when its all poured it will look like this. https://img.photobucket.com/albums/v...0/000_0693.jpg 7. now after you pour the devcon, you will need to skim your finger around the top of the sleeve, to 1, even out the pour, and 2. smooth it out. and make sure none of it sits above the gaset surface. there should be a bit of sleeve uncovered at the very top, prob like 1/16 inch. 8. let the devcon sit for 4 hrs. at room temp. then for 4 hrs it must be cured at 200 degrees. i put the block and a space heater inside a big box and let it bake out. be sure to keep a close eye on it, uncase you light up the box. hehe 9. let sit for another 18 hrs after that. 10. after it is hard. take an old headgasket. lay it on top of the block, and mark the coolant holes with your sharpie. 11. drill holes in the devcon 1 size smaller than the hole in the headgasket. https://img.photobucket.com/albums/v...0/000_0694.jpg 12. once holes are drilled, remove the freeze plug with a 19mm. 13. take your hose, and flush the salt out of the sleeves until you see no more coming out and the water shoots out of the holes drilled in the devcon evenly. 14. replace drain plug, and oil cyl walls to prevent rust. 15. hone or bore block and assemble. 16. drinka beer to celebrate your 50 dollar filled block and all the hard boost it will endure. https://img.photobucket.com/albums/v...0/000_0711.jpg brought to you by ccfab da stallion drinker. Modified by ccfab at 11:58 PM 11/24/2005 |
Re: diy filled b series block, with writeup, comments welcome (ccfab)
so how much boost do u think this will hold? have u tested it to see how much whp u can make? https://honda-tech.com/forums/images/smilies/emthup.gif to this plan though, def. beats $1000 sleeve job https://honda-tech.com/forums/images...s/emsmilep.gif
looks good...
but because of the salt the devcon will now pour past the salt... in effect its like a blockguard |
Re: diy filled b series block, with writeup, comments welcome (wantboost)
yes, it fills approx 1.5 inches of the sleeve. then it is drilled.
i would definately call it a hmt block guard. blacksi on hmt ran a simialr setup for 2 yrs in his drag car making 470ish whp at 32 psi on a t4/60-1 it has been run time and time again, i will personally be taking this block into the 20-25 psi range to see what happens there are also numerous people daily driving these filled blocks with no overheating issues whatsoeever https://honda-tech.com/forums/images/smilies/emthup.gif |
also, the devcon is of a thick consistency, and does not pour past the salt.
you must pack the salt in as tightly as possible. thats why i used table salt and not rock salt like some use. it is much finer and packs together much tighter |
ah, better than a blockguard then... that .5" inch piece of metal is a joke... this stuff is thikcer and it wont distort sleeves... im gonna try this with my d-series boosted go kart
interesting, gotta love the backyard specials https://honda-tech.com/forums/images/smilies/emthup.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab »</TD></TR><TR><TD CLASS="quote">it is much finer and packs together much tighter</TD></TR></TABLE>
https://honda-tech.com/forums/images...s/emsmileo.gif https://honda-tech.com/forums/images...s/emsmileo.gif |
Re: diy filled b series block, with writeup, comments welcome (RTErnie)
Re: diy filled b series block, with writeup, comments welcome (elitesi8)
another one from the boys of HMT! Great stuff! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: diy filled b series block, with writeup, comments welcome (thermal)
This is nothing new. Some know I am not really into the import scene, but very much into the domestic stuff. Filling blocks is really nothing new. Does it help...? ABSOLUTELY. In a domestic block you just fill the water passages up normally to the freeze plugs, sometimes all the way up. We run ours on methanol so no water is needed, so all our blocks are filled. It greatly strengthens the block itself. I cant give you a number for boost, but know when you have a 4.75" stroke billet steel crank swinging around in there at 7500+ RPM, you need as much strength as you can get....and we've never had any problems with it.
Kyle |
thumbsup
Re: (wade)
i saw this write up on d-series.org
im very impressed has anyone else on here used this w/o any cylinder wall issues? |
i have actually seen some V8 guys fill thier blocks completely with concrete, but these were on mud racers that only drive for about 10 seconds tho
Re: (mrbsponge)
some thign new to try out https://honda-tech.com/forums/images/smilies/emthup.gif
how easy is ti to mess up the block doing this? I am thinking of building a big boost motor and was interested..
THanks Stephen |
Re: (pythoner)
if you have any shred of patience and common sense, i cant see anyone ever messing up this install
Does the salt have to be kosher https://honda-tech.com/forums/images...s/emsmilep.gif
Re: (ccfab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab »</TD></TR><TR><TD CLASS="quote">if you have any shred of patience and common sense, i cant see anyone ever messing up this install</TD></TR></TABLE>
Ahh, and there in lies the problem! lol |
Re: (tony1)
lol... good point
common sense isnt so common, nor is patience |
I'm going to try this when I get my spare y7... I hope to get about 18psi out of my t3 with this setup....
Re: (pro547)
why does this work better than a block guard or does it?
Re: (Hella_JDM)
more metal to support the sleeves, doesnt require pressor file fitting like a blockguard so it wont/cant distort the sleeves.
Re: (wantboost)
true but he suggested to bore/rehone after the fill thats why i was wondering. why not fill all the way up and drill all the way down?
