BP Autosports welding/fab
#28
#29
Re: BP Autosports welding/fab
thats sick, we got one of those positioners at work. Ive used it for mig welding never thought of using it for tig though.
what bevel do you use. Ive been messing with some sch10 2.5" at work and I cant make a long pass with full penetration without overheating the stuff. I make a small bevel knife edge but dont get 100% penetration
#30
#31
Im not purging right now just practicing. but usually when purging I fill it first then set at about 10cfh.
But now Im not purging just practicing. once I see sugar or a bulge I know ive got decent penetration and probably have better penetration purging.
Im welding 100 amps at machine. So id say im at 80 amps most of the time. my bevel is about 1/4 of a inch. Im using 1/16 filler and basically having to push the rod into the puddle.
Ill try to weld some stuff at lunch tomorrow and see what happens.
#32
#38
Got my car on the dyno yesterday for some final tuning and manifold testing between two styles I offer. On the production manifold, we made 841/661 @ 35psi. On the stepped primary manifold with no other changes, we made 874/688 @ 35psi.
Dyno with production manifold:
Swapping manifolds:
Dyno after manifold swap:
Graph overlay:
The stepped manifold did exactly what I wanted and more. I'm absolutely stoked that my theories and research provided tangible power gains. I'll be reworking my manifold offerings with this new found data.
Swapping manifolds:
Graph overlay:
#41
Very nice fab/welding, inspiring
Good gains in the manifold swap. Im guessing the top manifold is 1.25 inch vs the second manifold is 1.25 inch stepping upto 1.5 inch ? Have you tried 1.25 vs 1.5 without the step up ?
#42
The other consideration is that the 2JZ head flanges really aren't designed for anything over 1.25" pipe, as they have the worst bolt placement I've ever seen on any head flange I've worked with lol
#44
They seem to operate under the principle of velocity versus volume. The heads, for example, flow like absolute **** on a bench (I was lucky to break 200cfm @ 0.390" [max lift I could achieve on factory components] with the GE head I ported at school), but when you put pressure to them, they really shine.
#45
-Intl Steve Krew
You've only been welding for 5 years and were self taught? How did you go about it? Pick up a book and a welder and just start sticking pieces of metal together?
(I just realized that bottom right pic might not be a pie cut bent tubing. But I think I made my point )
#46
I bought a TIG and started learning to use it out of necessity. I just did it, never read any books or anything in the beginning, just played around and got used to it over time. Over the past two years I really started giving a **** about getting better with it and focused all my attention to getting to be as good as I can.
#47
#48
#50
Some 3-1 collector work from today for one of my 2JZ-GTE Gen II twin scroll manifolds. These circular 3-1s are a blast to build:
