WTB: EG Rear Lower Shock Bolt
Corvette Forum Member
Good afternoon, guys! When redoing my suspension, the right rear lower shock mount bolt was seized inside the LCA bushing. The "welded" nut (if you can call it that) was my last resort before cutting the bolt off. The welded nut spun and snapped the bolt. I had to cut the bolt out of the LCA, ruining the LCA. I got the correct size/pitch bolt from the hardware store but I'm not sure about the grade of the bolt. It's an 8.8, but I'm kind of worried that I should have gotten something little stronger. Anyways, it's #15 in the picture. It's a 10mm/1.25pitch x 84mm long. Anyone got a spare one lying around? I've check part outs but havent had any luck with anyone responding. And FB Marketplace is a joke. Thanks!
