FS/FT: TWO Integras for one car. One is a DD the other is 540+Hp Race car!
I am looking to sell or mostly want to trade both of my cars for a single DD. I'm interested in a s2000, RSX-s, Nissan 350z or others, just throw me some offers, worst i can say is no.
First up is my built teggy. This is my 1995 Integra GSR. I want $10,000 obo. NO AC (Nothing under the dash or in engine bay), NO PS, NO ABS (converted to non abs). It has MINT MINT Black Leather Interior with absolutely no tears, that looks great! Does not have the wheels that are on the car! It has white GSR blades on rear with good tires, and a set of Rims with worn out MT's on the front. IT WILL COME WITH the other front blades to match the rears... Darton sleeved b18c1 bored to 84mm w/ copper O-rings CP 9.0:1 comp pistons Eagle H-beam rods OEM Honda oil pump OEM Honda water pump ARP rod bolts Balanced and blueprinted b18c1 crank ARP head studs ARP main bolts Golden Eagle (honda oem) 84mm head gasket Ferrea valves (stock size) Supertech valve springs and titanium retainers Honda oem valve stem seals Stock GSR cams Skunk2 cam gears Precision SC6169S converted to v-band (new) Vecco 28”/8”/3” Intercooler NGK Wires NGK Platinum Spark Plugs CC-Fab ram horn manifold 3 inch v-band down pipe 50mm Synapse Engineering wastegate BBK Single Stage intake manifold BBK 70mm Golden Eagle pro-series fuel rail Golden Eagle Thermal Intake Manifold gasket Precision 1000cc Injectors Aeromotive FPR w/ fittings FULL BLOWN Dual Walbro 255 AEM Uego wideband Autometer Boost Gauge Autometer oil pressure gauge Autometer Gauge pod Half Dual Core civic radiator SPAL 13" 1710cfm Slim Fan (i love this thing) Innovative Race Mounts Avid Torque Mounts Synapse synchronic bov Vented block and valve cover B&R fittings custom catch tank GSR Tranny w/Type-R LSD Action Dual Finger pressure plate w/6puk sprung disc ACT Prolite 9lb flywheel Hondata s300 with boost control Skunk2 Coilover with KYB AGE shocks in front SKunk2 Coilover Drag Launch Kit In rear HOW THE CAR SITS NOW: http://i30.photobucket.com/albums/c3...5/IMG_3024.jpg http://i30.photobucket.com/albums/c3...5/IMG_2449.jpg HOW THE CAR SITS ON BLADES. http://i30.photobucket.com/albums/c3...5/IMG_8129.jpg http://i30.photobucket.com/albums/c3...5/IMG_8130.jpg http://i30.photobucket.com/albums/c3...5/IMG_8131.jpg http://i30.photobucket.com/albums/c3...5/IMG_8132.jpg http://i30.photobucket.com/albums/c3...5/IMG_8134.jpg http://i30.photobucket.com/albums/c3...5/IMG_9308.jpg http://i30.photobucket.com/albums/c3...5/IMG_8141.jpg http://i30.photobucket.com/albums/c3...5/IMG_8144.jpg TRACK VID ON PUMP GAS and TIME SLIP: 95dc2teg Quest for 10's on PUMP gas - YouTube 95dc2teg (Anthony) at Bradenton Street Heat 4-9-11 - YouTube Same exact setup, different shell, dyno vid and sheets Pump Gas: http://i30.photobucket.com/albums/c3...5/DSCF0538.jpg Race Gas (112 oct): http://i30.photobucket.com/albums/c3...DSCF0548-1.jpg VID: phearable's Channel - YouTube NEXT UP IS MY DD INTEGRA SPECIAL EDITION: $4,000 is my 1995 Integra SE. 191,xxx miles. Motor replaced and has 99k, runs strong with no leaks and no smoke!! Good: 8k HIDS 00 front end and all red tail lights. AC/PS/CC/PW all work MINT GSR BLades Mint LS OG tranny, no grinds! Short Ram Intake MINT MINT clean Black Leather interior Drilled and slotted rotors all around (car stops crazy smooth and fast) New Brake master cyl Black headliner (looks really clean and done right, will take pics asap) Alpine head unit Polyurethane filled mounts (motor doesn't move at all!) Two new Tires in front. Lowered on H&R springs and rides like stock! eBay front camber kit Car is STOCK other than that Clean title Recent: Valve adjustment 8/7/11 Valve cover gasket and spark plug seals replaced 8/7/11 Spark plugs replaced with NGKs 8/7/11 Painted Wrinkle black valve cover, heat shield, throttle cable brackets 8/7/11 Re-painted all wiper blade arms to look new. 8/7/11 Tranny Fluid Change with Pennsoil Syncromesh 10/15/11 BAD: could use paint missing passenger door handle (will replace as soon as i find a teg at the local junk yard) couple dents here and there Pics: http://i30.photobucket.com/albums/c3...8260527_n2.jpg http://i30.photobucket.com/albums/c3..._7379001_o.jpg http://i30.photobucket.com/albums/c3..._8184724_o.jpg http://i30.photobucket.com/albums/c3..._3110071_o.jpg http://i30.photobucket.com/albums/c3...3_790351_o.jpg http://i30.photobucket.com/albums/c3..._5210837_o.jpg http://i30.photobucket.com/albums/c3..._2359175_o.jpg http://i30.photobucket.com/albums/c3..._4188861_o.jpg Interior: http://i30.photobucket.com/albums/c3...6_391357_o.jpg http://i30.photobucket.com/albums/c3..._1786066_o.jpg http://i30.photobucket.com/albums/c3..._7163441_o.jpg Engine: http://i30.photobucket.com/albums/c3...5/IMG_2180.jpg Lowered on H&R springs: http://i30.photobucket.com/albums/c3...5/IMG_3268.jpg http://i30.photobucket.com/albums/c3...5/IMG_6986.jpg http://i30.photobucket.com/albums/c3...5/IMG_5575.jpg $4,000 Thanks for looking! |
Re: FS/FT: TWO Integras for one car. One is a DD the other is 540+Hp Race car!
Top
Ttt
Ver
Very nice
ttt
PMed :)
