IN FS: 1992 Honda Civic Turbo Hatch
Old 06-19-2019, 06:12 PM
dirtnastyhatch's Avatar
Default FS: 1992 Honda Civic Turbo Hatch
I've had a lot of fun in this car, and learned even more, but I now simply have to many vehicles and need to part with some of them.
For sale is a very clean 1992 civic hatch with a turbo D16Y8.
1300cc injectors, Holset 62mm turbo and forged rods. Built to handle a reliable 500hp.
Has boost by gear and is set to 20psi in third gear. This car is a driver's car and is not for the faint of heart, it's a lot to handle on the street. Has full interior. Dyno'd at just shy of 340 whp with a log manifold on 16psi, now has a tubular mani at 20 psi & e85. I estimate around 400whp as it sits.
Engine:
D16Y7 Block with Y8 Head
Head has been ported on the exhaust side and casting lines have been cleaned up on the intake side.
Bisi 3.6 Cam, Crower Springs supertech seals.
Was milled by Jimmies Motor Machine before assembly
ARP Head Studs
OEM Head Gasket
Block work was done by Schmidt Competition engines in Indy
76mm bore - Vitara Pistons
Eagle Rods with ARP bolts
ATI Super Damper
ACL HX Race Bearings - Mains and Rods - Standard Size Crank Journals
Journals were polished
Ported Oil Pump
New OEM water pump
New OEM timing belt
Bosch 1300 Injectors
Walbro 255 Pump
Ported Intake Manifold
70mm Throttle Body
Go auto works mini ram
Holset HE351CW Turbo - 60mm
Treadstone Intercooler
HKS Style BOV
EMUSA Wastegate
Y8 Transmission
Comp Clutch 2600 Kit
New Poly Mounts and shift bushings
Short Shifter
Oversize Radiator with custom slim fan/shroud
Hasport ultra stiff engine mounts
Dunlop Direzza Tires with ~80% Tread left
Hondata S300V3 w/Full throttle shift and boost by gear enabled
Tuned on E85 for performance but has a flex fuel sensor so can run on 93 at the pump. The tone is actually very on point to run either fuel. Street and strip tuned.
Interior:
Black GSR Dask for a very sporty look vs. the stock hatch dash
- Full working GSR cluster with Additional gauges to monitor vitals (oil pressure, boost and afrs)
Sparco Race seats
Rear seat delete with custom cut carpet in the rear to keep it clean.
Integra Type R climate control cover (carbon fiber)
ITR shift boot
ITR Center console m
Full interior otherwise.
Exterior:
Was blue originally, they did a pretty good job on the black paint job, though some of the clear coat is starting to fade and peel.
Tein adjustable coil over Suspension all the way around
GSR Disk Brake rear conversion
Integra Type R rear sway bar
Rear upper cab stiffener
Also comes with some 24.5X9R13 MT ET Slicks and a spare trans
Has beat up on numerous muscle cars including a z06, turbo gt's etc.
California car, zero rust. Clear title in my name.
Would be glad to send more pictures to serious buyers that have cash for the list price above. Price is firm, please do not waste our time.
It's a 92 year model, so do not expect it to be pristine. It is very very nice for its age though. Price is very reasonable considering the list this thing has.
$6,000 OBO as it sits
$5,200 without the Genuine Sparco race seats would come with very nice black seats
$4,800 on steel wheels and very nice standard black seats
Willing to trade for diesel tucks only, no single cabs.
Please do not ask me about any other trades. You will not receive a response, or I'll be an a$$hole.
Thanks for looking and keep on wrenching!
Last edited by dirtnastyhatch; 06-21-2019 at 07:18 AM. Reason: Adding pictures back in, adding price. More pictures
dirtnastyhatch is offline
Old 06-20-2019, 10:24 PM
Jack Hon's Avatar
Default Re: FS: 1992 Honda Civic Turbo Hatch
How much is it?
If possible please text 909 630 6910
Jack
Jack Hon is offline
Old 06-23-2019, 09:43 AM
Bump
Old 07-15-2019, 11:48 AM
jsgarcia's Avatar
What did you have to do to install the integra dash? Looks neat for the hatch,
Bump
jsgarcia is offline
Old 07-19-2019, 10:30 AM
kayelemenohpee's Avatar
Good price. I have no connections if I purchase this will I be able to smog and Reg. this car in CA?
kayelemenohpee is offline
JANDB04
12-02-2007 08:56 AM
NeWnMpR0VeD
06-14-2006 02:03 PM
Quick Reply: IN FS: 1992 Honda Civic Turbo Hatch
