1985 Toyota Corolla AE86 SR5 Beams 3SGE 6 Speed
Thanks for looking at my ad
Car is on ebay now with autocheck verifying no accidents and 2 owners :-) http://cgi.ebay.com/ebaymotors/Toyot...item1c2e8243bb Location: South Florida Contact: Text 954 401 987(two) or email gcarre23@hotmail.com Hello Folks. I never wanted to have to sell my car, but to make it short and sweet, my girlfriend and I are expecting a baby and my focus in life has changed over the last couple of months. The ae86 has to go :-( 1985 Toyota Corolla SR-5 - Clean Clear Title Original Paint Original Interior No Cracks In Dash Super Clean Inside and Out - No Accidents I am the 2nd Owner for over 8 years Asking $13.5k - Shipping Inside and Outside of the USA available The drivetrain swap was done professionally and the motor is wired up to look and operate like factory using the factory ECU, Harness, even the ECU Box. The car starts right up every time, functions flawlessly, sounds awesome and turns heads / breaks necks. No oil leaks, no smoke. If you know these cars the pictures and parts list speak volumes for the vehicle. There is no other corolla like this in the USA. Body- Original Paint with Original South Eastern Toyota Dealer Association "SS Coupe" stripe package - Dealer Installed when new. Complete JDM Zenki Front End - All Purchased New OEM Zenki JDM Front Bumper Zenki JDM Front Lip Lights / Emblem / Brackets / Grill (Rare - Discontinued) Complete JDM Zenki Rear End Zenki JDM Bumper (Used - Clean - Discontinued) New OEM brackets Kouki GTS Trunk garnish Zenki JDM Smoked Tail lights (Clean - No Cracks) Other TRD N2 Mirrors (Rare - Clean - Purchased New) Carbon Fiber Hood (Clean - No Cracks - No Fade) Carbon Head Light Covers (Clean - No Cracks - No Fade) HID lights New OEM Rear Quarter Window Metal/Rubber Moldings Suspension- FRONT Custom Coil Over (Shortened Strut Casing w/ strut spacer)) 350 lb springs KYB AGX (sw20) New OEM Control Arms with Urethane bushing Megan Tension Rod Megan Outter Tie Rod Megan Inner tie rod Tein camber plates Strut Tower Bar Tanabe Sway Bar Custom Wilwood 4piston brakes (Big - only fit inside TE37 wheels) UEO bomber bar UEO fender braces OEM Manual Rack + OEM Manual Column Quaife Quick Steer Manual Rack Gear (Rare) New OEM steering rack bushings Suspension - REAR 1980 Supra Axle 7.5 inch - Completely Rebuilt End to End Eneos Fluid New Alxle Bearings and Seals New Diff Carrier Bearings Supra MK2 Clutch LSD with Weir Performance Rebuild Kit + Solid Pinion Spacer TRD Springs 4.2kg KYB AGX (Camaro) Tanabe Sway Bar TCS Strut Tower Bar Custom Traction Brackets Welded Custom OEM adjustable lower control arms Complete urethane bushings Custom Panhard adjustable with heim joints Drivetrain- Toyota Altezza RS200 3SGE Beams 4th Generation Motor - 210 HP - 11:1 Compression - 8k rpm redline Toyota Altezza RS200 6Speed Cross Ratio Transmission Factory ECU + Engine Harness Low Mileage Swap with new timing belt service and recent clutch Custom Steel Driveshaft - Balanced Custom Front Subframe + Aluminum Trans Mount Custom Mishimoto Radiator + Fan + Shroud Custom Intake Custom Fuel System @ 62psi (Same fuel system from my old 400HP setup) Custom Secondary Exhaust Runners to 2.5 Mandrel Bent Over Diff Exhaust with Rare Nissan - Impul Super Muffler 60mm Full Stainless Muffler Interior- GTS Cluster NRG Harness Bar Gforce Driver Harness and NRG Passenger Harness NRG Quick release Custom OEM Toyota Altezza Stainless Pedals Titanium Shift knob OEM MOMO Honda Steering Wheel with TRD horn button Carbon Fiber Shifter Console Complete Clean Interior Wheels/Tires- 15x7 Volk TE37 in Magnesium Blue Volk Center Caps Project Kics Composite Lugs Falken Azenis 205-50-15 Pics- https://i922.photobucket.com/albums/...e/STH71029.jpg https://i922.photobucket.com/albums/...e/DSC_7721.jpg https://i922.photobucket.com/albums/...e/DSC_8241.jpg https://i922.photobucket.com/albums/...e/DSC_8105.jpg https://i922.photobucket.com/albums/...e/DSC_8096.jpg https://i922.photobucket.com/albums/...e/DSC_8065.jpg https://i922.photobucket.com/albums/...e/DSC_8040.jpg https://i922.photobucket.com/albums/...e/DSC_7791.jpg https://i922.photobucket.com/albums/...e/DSC_7770.jpg https://i922.photobucket.com/albums/...e/DSC_7740.jpg https://i922.photobucket.com/albums/...e/DSC_7729.jpg https://i922.photobucket.com/albums/...e/DSC_7254.jpg https://i922.photobucket.com/albums/...e/DSC_7332.jpg https://i922.photobucket.com/albums/...e/DSC_7331.jpg https://i922.photobucket.com/albums/...e/DSC_7329.jpg https://i922.photobucket.com/albums/...e/DSC_7328.jpg https://i922.photobucket.com/albums/.../DSC_08262.jpg https://i922.photobucket.com/albums/...e/IMAG0618.jpg https://i922.photobucket.com/albums/...e/IMAG0616.jpg https://i922.photobucket.com/albums/...e/IMAG0552.jpg https://i922.photobucket.com/albums/...e/IMAG0547.jpg https://i922.photobucket.com/albums/...e/IMAG0490.jpg https://i922.photobucket.com/albums/...e/IMAG0489.jpg https://i922.photobucket.com/albums/...le/ae86gtr.jpg |
Re: 1985 Toyota Corolla AE86 SR5 Beams 3SGE 6 Speed
bump thanks for lookin yall
bump! thanks for looking
Bump for looking....that interior takes me back to the 80s for sure lol. Good luck with the sale!
thanks!
