$8,000 '99 Accord 3.5L Supercharged 6speed. NEED GONE
Long story short, I need ACL reconstructive surgery and am going to be paying for most of it out of pocket. I NEED THE CAR GONE. I will not budge from $8,000 considering this is incredibly lower then I originally wanted to sell for.
Westchester NY https://img.photobucket.com/albums/v...cka/Image1.jpg Custom painted -2nd Owner. Bought from guy in his 60's with 59,000 miles on it. Since then engine is new and transmission is new. Body has 128,000 miles on it Engine has 8,000 miles on it Transmission has 20,000 miles on it Supercharger has 10,000 miles on it Leather Interior (non smoker) Body is practically mint (few minor scratches from being daily driven) *Dent/scratch on passenger side door from parking lot *Driver seat leather cracking (128k miles of use) Regular maintenance on the car for the 10 years I've owned it including 93 gas and full synthetic oil every 2,500 miles Car made 325 horse power at the wheels with 299 lbs of torque on 7 psi with the Comptech USA superchager. (video in 6thgenaccord.com link) Since then I have removed the upgraded fuel system and gone back to stock due to car wanting to stall when coming to a stop. (daily driving the car it just became something i did not want to deal with) http://img.photobucket.com/albums/v282/rocka/432-1.jpg https://img.photobucket.com/albums/v...a/IMG_6493.jpg [VIDEO]3.5 S/C 6spd AEM F.I.C. Dyno Tune 12/10/11 - 6th Gen Accord DIY and Performance Forums I WILL BE INCLUDING THE HARNESS AND AEM FIC WITH SALE. I HAVE NO NEED FOR IT Car is currently 3.5 liter supercharged running of a 2003 Acura CL 3.2 ECU. Car runs very strong with no issues. *Stage 3 pressure plate installed on this car and it causes a VERY VERY stiff clutch pedal. I was one of the 1st if not the 1st with the Clutch Masters kit for CL-S transmission. Partial sponsorship from Mishimoto In grassroots of HondaTuning Feb/2010 Below is the current modification list and everything is included. Custom 3.5L Acura CL Type S Engine » '03 CL Type-S Engine » '03 CL Type-S Pistons » '01 Odyssey Crankshaft » '01 Odyssey Connecting Rods » '01 Odyssey Connecting Rod Bearings » '01 Odyssey Main Bearings » '07 TL-S Exhaust Valve Springs '03 CL Type-S ECU '03 CL Type-S 6 Speed Manual Transmission ClutchMasters Lightweight Aluminum Flywheel ClutchMasters Stage 3 FX300 Pressure Plate ClutchMasters Full Face Kevlar Clutch Disk Comptech USA 3.2 Acura CL SuperCharger P2R Power Plenums AEM Wideband o2 Sensor Innovative Motor Mounts Custom Cold Air Intake DEI Gold Heat Deflector Intake Tape ComptechUSA Headers DEI Black Header Wrap Custom 2 Ύ" Exhaust Piping Magnaflow High-Flow Catalytic Converter Magnaflow 3" Muffler Magnaflow 3" Resonator Unorthodox Racing Under Drive Pulley Kit Walbro 255ml Fuel Pump Comptech Fuel Pressure Regulator Omni-Power '00 Honda Civic Quick Clutch Master Cylinder Corsport Aluminum Shift Linkage Bushings Odyssey 140amp Alternator Taylor Aluminum Battery Box Mugen Thermostat Mugen Fan Switch Universal Oil Catch Can Mishimoto Aluminum Performance Radiator (5th Gen Accord) » *Custom Made Top Mounts Mishimoto Aluminum Fan Shroud (5th Gen Accord) Mishimoto 12" Slip Cooling Fans Mishimoto 1.3 Bar 19lb Radiator Cap Suspension: Tein SSP Coilover with Pillow Ball Upper Mounts Tein Electronic Damping Force Controller (EDFC) Tein Help Springs Ingalls Front Camber Kit Ingalls Rear Camber Kit Neuspeed Front Upper Strut Bar TASauto.com Rear Lower Tie Bar Megan Racing C-Pillar Brace Cross Drilled/Slotted Rotors 17"x8"+45 Flat Black Acura TL Wheels P235/45R17 Goodyear Eagle GT Tires Interior: Momo Euro Type-R Steering Wheel KPH Instrument Cluster w/ Hyperwhite L.E.D.'s Blue L.E.D. Clock Bulb Conversion Hyperwhite L.E.D. Interior Lights Custom Single Pod A-Pillar (AEM Air/Fuel) Custom CD Tray Toggle Panel Exterior: WingsWest Full Lip Kit Custom BMW Interlagos Blau Metallic Paint Custom Black Housing HeadLamps "Type-R" Mesh Grille OEM Trunk Spoiler Cobalt SS "SuperCharged" Emblems Custom Wired "JDM" Yellow Fog Lights in Highbeam 12,000k H.I.D. Conversion Engine/Transmission: Built at 50/50 Movement Teterboro, NJ Tuned at Chris Miller Racing Farmingdale, NY In Car Electronics: AEM Digital Boost Gauge AEM Digital Air/Fuel Gauge This is the most recent craigslist add 99 Accord Coupe 3.5L Supercharged 6spd M/T additional photos can be found here »Form follows Funtion« MikeyMike's »3.5 »S/c »6 Speed MT »Coupe [Updated 2/20/11] - 6th Gen Accord DIY and Performance Forums |
Re: $8,000 '99 Accord 3.5L Supercharged 6speed. NEED GONE
bump
bump
