Too much ATF
No, I'm not going to overfill it on purpose. Just wondering if there is any harm by going a bit over the top (of the dip stick).
Motor oil, for example when you overfill it, will boil over and/or foam up. So that's not good. Will ATF do something similar? |
Re: Too much ATF
Motor oil or tranny fluid, a little extra is not gonna cause any issues, like 1/2 quart or less.
A D16 with run just fine with 7 quarts of oil in it, but it sucks when you only have a 6 quart pan and doing an oil change! My DD Accord calls for 4.5 quarts of oil, I dump in the full 5L/5.2 quarts from the big jug. I uses/leaks 3/4 of a quart every 1500 miles that I drive a week. |
| All times are GMT -8. The time now is 05:58 AM. |
