Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Transmission & Drivetrain (https://honda-tech.com/forums/transmission-drivetrain-127/)
-   -   ring gears? (https://honda-tech.com/forums/transmission-drivetrain-127/ring-gears-2710552/)
t3601 Jan 13, 2010 03:54 PM
ring gears?
does anyone know how many teeth are on what ring gears? It has been a while since i dicked around with differents tranny's. So if anyone know how may teeth are on the b16, gsr, ls, if jdm tranny's are different. I tried the faq's but couldn't find anything
t3601 Jan 14, 2010 11:23 AM
Re: ring gears?
somebody has to know how many teeth are on what ring gears.
Mista Bone Jan 15, 2010 06:17 PM
Re: ring gears?
I know, Bense knows, others know as well, it has been posted before.
Or you could just do the math....not hard.
t3601 Jan 18, 2010 11:53 AM
Re: ring gears?
so here is what I found out. if i'm wrong please correct me.
B16 has 66 teeth/final drive 4.40
GSR has 66 teeth/final drive 4.40
ls has 64 teeth/final drive 4.26
the counter shafts all have 15 teeth on them but are different in diameter size.
LIKE I SAID, IF ANY OF THIS IS WRONG PLEASE CORRECT ME...
Mista Bone Jan 19, 2010 01:01 AM
Re: ring gears?
what is the issue?
t3601 Jan 19, 2010 04:48 PM
Re: ring gears?
^^^^ the issue is that I was givin 3 tranny's dissasembled in a box. tryin to piece them together. kid I got it from thought he knew what he was doing and couldn't figure out how to put them back together. I'm using 1-4 b16, and ls 5th, so I'm using the b16 counter shaft and main shaft and needed to know which ring gear is for the b16 counter shaft. but I already figured it out and it works great. first time nobody on here could help.
