5th gear cuff bearing size question
I was hoping that someone could tell me the bearing size that goes on the mainshaft side of the 5th gear cuff. I purchased the cuff about a year ago, never really opened the boxes at the bearings came in, as I was stock piling parts for my build. But once I started to install it on the transmission I soon realized that I got sent two of the same bearing , by accident im sure. As you can see in the pictures, when that bearing is on the main shaft side there is about a quarter inch gap. Was just curious if anybody had the bearing size that goes on the main shaft side so I can put the trans back together. I currently in contact with Synchrotech but I’m sure I won’t be able to find my invoice since my purchase was quite some time ago. Thanks for any help.
Re: 5th gear cuff bearing size question
I suggest you give them a call and tell them your story. At worst, you may have to buy a replacement bearing. At least they will know EXACTLY what you need. Good luck.
