odd squeal in ITR transmission
My J4D ITR Tranny has developed an odd squeal. It only occurs after 15+ mins of driving. It seems more prominent once I let the car decelerate to under 10km/h and then clutch down and release the gear, then I will hear this squeal. I'm thinking the release bearing, but the sound still remains whether I clutch down or not. The only difference is that the tone of the squeal changes when I engage the clutch. The noise will go away if i keep pumping the clutch up and down, or if i give it a bit of gas right at the friction point. Is this my release bearing... or is it main/input shaft one in the tranny?
Thanks |
Re: odd squeal in ITR transmission
sounds more likely to be a throw out bearing. some of the cheaper ones don't live so long. i would just buy a new clutch kit and check the input shaft when you have the tranny out. see if there is any play
So a bit of an update to this
removed the tranny and swapped out the throwout bearing, main bearing and pilot bearing. Noise still apparent. One thing I noticed was that there was a groove starting on the Pressure plate. The shop said that was normal however. I just read that a fork could cause the pressure plate to mess up and thus cause this noise? |
clutch disc has popped out a spring, typical B series.
Where was the groove on the pressure plate? |
no wear on the area near the springs or stress fractures, clutch looks fine. The wear is on the fingers of the pressure plate where the throwout bearing touches
