Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Transmission & Drivetrain (https://honda-tech.com/forums/transmission-drivetrain-127/)
-   -   Need help identifying CV axle (https://honda-tech.com/forums/transmission-drivetrain-127/need-help-identifying-cv-axle-3371140/)
ajcrain Sep 1, 2023 10:22 AM
Hello, I have a 95 eg coupe with a jdm h22a swap in it that i bought a few months ago. It has Hasport motor mounts.
I recently replaced the passenger side cv axle in hopes to get rid of a shudder during hard left turns… didn’t fix it but that’s besides the point.
I used a replacement axle from rockauto off of a 95’ Integra. (Previous owners recommendation) This fit perfectly.
Now, I ordered the drivers side axle too (95 Integra) but it is different. It had a female end rather than the male. There are a few numbers on the boots of the old shaft… looked them up and couldn’t find much. Maybe somebody can help me here.
So does anybody know what axle this is? And what one I can buy that will work? Thanks.
https://cimg4.ibsrv.net/gimg/honda-t...9b1b884b6.jpeg
Old on top, new on bottom (drivers side)
https://cimg9.ibsrv.net/gimg/honda-t...cf7367c8a.jpeg
https://cimg3.ibsrv.net/gimg/honda-t...6c0c9256f.jpeg
https://cimg8.ibsrv.net/gimg/honda-t...4aa4c872f.jpeg
https://cimg3.ibsrv.net/gimg/honda-t...effc37046.jpeg
https://cimg5.ibsrv.net/gimg/honda-t...29cbac939.jpeg
Hasport Sep 1, 2023 12:37 PM
Re: Need help identifying CV axle
there are no off the shelf axles that will work for h22 swaps
the axle you pulled out that has male ends on both sides is from a 90-93 integra
the reason you have a shudder when making turns is the axle is too long and it is binding up
ajcrain Sep 1, 2023 12:51 PM
That is interesting because the shudder began after a long road trip with the car. As far as i can remember it did not shudder before (with the Integra axles). It only began a short while ago.
Shudder was very bad with worn motor mounts, after mounts replaced it only happens mildly when going straight, and pretty bad when turning hard left.
ajcrain Dec 18, 2024 05:18 PM
I’m gonna bump this… a year later. Shudder is still there. Replaced the axles, suspension feels tight. Can’t feel any movement of wheel with the car off the ground.
Shudder in passenger side wheel area happens when accelerating and turning left at speeds. (Can turn left slowly with wheels locked with no axle binding)
I have no idea what’s causing it and I’m losing hope. Someone please help me :cry:
