BMXA - Reverse slips after Rebuild
Hi,
I just got done rebuilding my 2003 Civic BMXA. I replaced all the clutch packs, seals, filter, torque converter, and radiator... I did not replace the mainshaft O-rings because there weren't any in the kit. I did not replace any springs in the valve bodies because there were all good. I put the shift fork back the way it should be.... some say to make sure and put the ring and race right side up.
Now that the car is up in running.. it drives and shifts perfectly... But while in reverse going backwards up a hill (we live on a hill) it slips / shudders... Can someone help me diagnose that? I really don't want to pull it all apart again if I don't need to.
I only put 5 miles on the transmission so far... Should I drive it more and maybe the problem goes away???
Re: BMXA - Reverse slips after Rebuild
Thyanks for the demonstration bud!! Very accurate!
My rebuild shudders and slip in reverse...I know weird.
All mechanical is good and right..Possible bore wear for apply piston? I know uncommon lol
Valvebody somewhere?
gstrudler
Transmission & Drivetrain
06-03-2013 02:28 PM
