Transmission & Drivetrain Gearboxes, Differentials, Clutches
Civic Hx Cvt tranny help (automatic) will it work with other D-series auto transmissions?
Old 04-11-2005, 09:38 AM
flipcivicvtec's Avatar
Default Civic Hx Cvt tranny help (automatic) will it work with other D-series auto transmissions?
HI everyone i have a 99 civic Hx and my trans is slipping
I was told i will need a rebuild
But the civic Hx comes with a rare and expensive transmission with CVT that i cant afford to rebuild
I have found 96-00 civic ex and dx trans on ebay for cheap, will these trans fit my hx with no problems??
THANKS
flipcivicvtec is offline
Old 04-11-2005, 01:45 PM
LVB18Civic's Avatar
Default Re: Civic Hx Cvt tranny help (automatic) will it work with other D-series auto transmissions? (flipc
I am a Honda Technician and I know that at my work we always warranty HX auto transmissions. I have done them on HX's with 150,000 + miles. I would check your local Honda Dealership and you might be able to get a Honda Reman. Trans under warranty.
Just a thought.
And to answer your question those trannys will fit but I don't know how the ecu will react.
LVB18Civic is offline
Old 04-11-2005, 02:02 PM
no its not covered under warranty because it has 250k miles
if i was gonna use an ex trans can i just use a ex ecu??
Old 04-11-2005, 04:41 PM
bump
help me out anyone
Old 04-11-2005, 08:06 PM
LVB18Civic's Avatar
Yes you could use a auto ex ecu if you put in the ex auto trans.
Old 04-11-2005, 08:25 PM
ok so all i need is a 99-00 ex tranny and a 99-00 ex ecu and i should be fine huh?
can i use a 96 ex trans and use a 99 ex auto ecu since its obd2b
Old 04-11-2005, 09:51 PM
OBD2 Automatic to OBD1 Automatic Conversion Harness
1996-2001 Acura Integra
1996-2000 Honda Civic
1996-2001 Honda Prelude
1996-2002 Honda Accord
1996-2000 Honda Odyssey
$250 with FREE FedEx Shipping!
This harness allows the use of OBD1 auto transmission & ECU in an OBD2 automatic vehicle.
You must use the following:
OBD1 Auto Transmission
OBD1 Auto ECU
OBD1 Transmission Control Unit (TCM)
These are made to order, please call and we will build one to suit your exact needs!
wil this help me out?? will it make my swap easier going with obd1 engine w/ obd1 trans swap ??
Old 04-12-2005, 01:24 PM
so u think i can use this harness to use an ex obd1 tranny and computer
i really dont wanna use another hx cvt tranny, those shiftless trannys suck!!
cvt sucks!! i rather use a dx or ex
Old 04-13-2005, 10:45 AM
bump need help
Old 04-15-2005, 07:49 PM
can i just convert hx to ex??
Old 07-25-2010, 02:02 AM
cejota22's Avatar
hey bud how did you make out with the trany swap did everythin bolt on did it work i have the same problem
cejota22 is offline
Old 07-25-2010, 04:07 AM
Resident Gearhead
BryanM.'s Avatar
I doubt the Y5 would run correctly using a Y8 ECU for several reasons.
BryanM. is offline
Old 07-25-2010, 12:07 PM
cejota22's Avatar
so would a ex auto transnision fit a hx model with harness and the ecu would everyhting would plug nd play kind of thing or mods has to be made
cejota22 is offline
Old 07-25-2010, 12:30 PM
DVDr's Avatar
I dont think the guy still posts here, specially because it was a 5 year old post.
But, you can install the transmission no problem as long as you use the correct ecu , this case EX .
But the problem is the Y5 does not RUN well/correctly with the EX ecu. So while you are at it, swap out the Y5 and install a y7 or y8 and transmission of liking with ecu of the motor you picked up.
DVDr is offline
Old 07-25-2010, 02:56 PM
cejota22's Avatar
so its best to do a whole swap motor and trans from a y7 or y8 trany,motor,harness and ecu rite save hasle
cejota22 is offline
Old 06-04-2018, 09:37 PM
Bryan Done's Avatar
I'm going to test this theory.
Bryan Done is offline
redm3turbo
07-26-2011 05:40 PM
jdeemseerx
02-28-2007 09:35 AM
crxnonvtec
12-22-2005 10:44 AM
Kennysr6
41
07-28-2004 07:34 PM
civicrtype
10-08-2002 12:28 AM
Quick Reply: Civic Hx Cvt tranny help (automatic) will it work with other D-series auto transmissions?
