Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Transmission & Drivetrain (https://honda-tech.com/forums/transmission-drivetrain-127/)
-   -   cable to hydro conversion (https://honda-tech.com/forums/transmission-drivetrain-127/cable-hydro-conversion-2630311/)
hatchet_honda Aug 19, 2009 10:15 AM
i have a hydro gsr trans in my 90 hatch with a b16a. well im using the hasport master cylinder adapter and the release sucks. anyone have better luck with a diff setup? i have a cable ls trans but that requires a new mount and diff clutch disc and rear bracket
Hasport Aug 19, 2009 10:48 AM
Re: cable to hydro conversion
what master cylinder are you using on the CMA?
phunhaus Aug 19, 2009 01:02 PM
https://honda-tech.com/forums/showth...ighlight=sonem
hatchet_honda Aug 19, 2009 10:52 PM
oem honda master cylinder. maybe an aftermarket would work better?
hatchet_honda Aug 19, 2009 10:56 PM
Originally Posted by phunhaus (Post 39681203)
ive seen that lil bracket thing a few times....actually thought about it at first, havent even that setup used yet tho. id fab that bracket myself if i did go that route. dunno bout rippin out my vent tube and all
brian g Aug 20, 2009 10:50 AM
It shouldn't, there may be another problem. What is it doing, releasing too soon, too late?
brian g
hatchet_honda Aug 20, 2009 08:05 PM
brian g
doesnt quite grab till the very top of the pedal....ive bled the line many times. big diff between driving my daily d15b with a cable trans and this hydraulic frankenstein in my b16 swap ef.
brian g Aug 21, 2009 07:23 AM
You should be able to adjust the cable now until you get the release right where you need it.
brian g
bryse68 Aug 21, 2009 12:13 PM
i have the sonem setup in my crx with a hydro gsr, works great.....eliminates that POS cable completely......
