Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch or tranny issue
Old 03-02-2017, 11:56 AM
Mr.Death's Avatar
Default Clutch or tranny issue
Truck is 2000 honda CRV with the B20 motor, manual transmission.
Issues:-
- Hard to shift into all gears
-pedal feels solid
-Sometimes when clutch is depressed in Fist gear its still slightly engaged(drags), car creeps forward.
-Clutch engagement is not smooth, when releasing clutch half way I hear scraping in transmission as if clutch disk is starting to engage too soon
-I replaced master cylinder because it was leaking. I thought this would fix the issue but still it persists.
-slave cylinder appears to be good. Not leaking. I took it apart and rebuilt it. All seems good
I'm thinking clutch release bearing/throwout bearing or faulty clutch....
. It seems like these are the symptoms of a bad master cylinder but that was replaced and system was bled properly
Any ideas before I go out and buy a new clutch? Thanks
Old 03-03-2017, 03:59 PM
Aquafina's Avatar
Default Re: Clutch or tranny issue
If there is any friction when the clutch disengaged then you have a problem with the clutch system preventing the clutch from fully disengaging. If the release bearing is bad it will make a noise.
Old 03-04-2017, 12:45 AM
holmesnmanny's Avatar
It sounds like there is either not enough clutch free play or way too much free play, more likely too much free play.
Old 03-05-2017, 05:37 AM
Mr.Death's Avatar
No issue with the clutch disengaged. Release bearing is quiet.
Old 03-09-2017, 09:12 AM
Aquafina's Avatar
Check the master and slave for leaks and verify it is 100% air free.
DenisR
02-19-2016 05:09 PM
komat
08-06-2010 12:04 PM
luis666
08-15-2006 01:59 PM
bboychris
10-07-2002 11:48 PM
fiebru1119
08-20-2002 10:07 AM
Quick Reply: Clutch or tranny issue
