Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   wiseco piston hitting Oil squirter Jets (https://honda-tech.com/forums/tech-misc-15/wiseco-piston-hitting-oil-squirter-jets-1000978/)
82lude Sep 23, 2004 05:15 PM
Anyone here have a problem with there wiseco pistons hitting the oil jets on a b18c1. I thought that I had piston slap at first but when I pulled out the oil pan I found the nozzle of the #4 oil jet in the oil pick up. It seems that the wrist pin support rib was pushing the nozzle down then the crankshaft journal pushed it back up. I was just wondering if anyone had to grind down their pistons for this also?
Thanks!
92HB_HB Sep 24, 2004 09:20 AM
Re: wiseco piston hitting Oil squirter Jets (82lude)
i have the same problem.. the squirter broke right off twice and was in the oil pick up... i guess its not an isolated incident.. btw, i'm runnin a gsr w/ 84 mm weisco's as well... also, #4 piston is the closest to the timing belt, correct?? cuz that's the one that's having the problem...
help would be appreciated...
JDM_Honda_Fiend Sep 24, 2004 09:24 AM
Re: wiseco piston hitting Oil squirter Jets (92HB_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote"> also, #4 piston is the closest to the timing belt, correct?? cuz that's the one that's having the problem...
help would be appreciated...</TD></TR></TABLE>
Piston #1 is closest to the timing belt. https://honda-tech.com/forums/images...es/emsmile.gif
82lude Sep 24, 2004 01:17 PM
Mine was also the #4 piston farthest away from timming belt. So I ground down part of the pistons. All the squirters were hitting the pistons.
Slow_Em1 Oct 15, 2004 09:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem.. the squirter broke right off twice and was in the oil pick up... i guess its not an isolated incident.. btw, i'm runnin a gsr w/ 84 mm weisco's as well... also, #4 piston is the closest to the timing belt, correct?? cuz that's the one that's having the problem...
help would be appreciated...</TD></TR></TABLE>ihave same probelm...found 2 nozzles in my pickup last night...im at 84.5mm bore IB spec wiseco's...is this dangerous? http://images.honda-tech.com/set1//smile/emcrook.gif
H22coupe Oct 20, 2004 11:58 AM
Re: wiseco piston hitting Oil squirter Jets (TodaFiend)
Did any of you check for clearance between you oil jets and crank/pistons? Also, were these instances of jets hitting with GSR cranks or LS cranks?
PreStaged12s Oct 20, 2004 12:32 PM
Re: wiseco piston hitting Oil squirter Jets (H22coupe)
I had a machine shop but my B18C1 block together, im using 81.5mm Wisecos from IB, reason they hit the oil squirters is because of the slip skirt design on the piston, the maching shop billed me for an extra hour of labor because they set up the oil squirters so they could properly function without being harmed, so your not the first to have this problem.
wHOAlly Oct 20, 2004 01:48 PM
Re: wiseco piston hitting Oil squirter Jets (PreStaged12s)
another reason i plugged em.
http://www.akumay.expohl.com/stuff/r.../assembly1.jpg
93lsd Oct 20, 2004 04:31 PM
i put a block tock together for a friend using wiseco pistons about a year ago and had the same problem but i also check too see if the crank spins freely before puting everthing else together and noticed they were hitting so i just plugged them the same as the pic
DonF Oct 20, 2004 04:42 PM
Re: (93lsd)
Yes, you either have to modify the oil tube or remove it. Whoever did the piston design TX. or Ca. missed it.
lohatch Oct 20, 2004 05:06 PM
Re: (DonF)
Tbone modified his to work. hit him up and maybe he can help https://honda-tech.com/forums/images/smilies/emthup.gif
dome Oct 20, 2004 05:37 PM
yeah i had to plug mine too. i stuffed a ls crank in my gsr and 3 out of the 4 were hitting either the crank or piston. it too was bored to 84mm.
PyroProblem Oct 20, 2004 05:42 PM
Re: wiseco piston hitting Oil squirter Jets (dome)
Hmmm. I wonder if thats the noise in my engine?
I also have wisecos in my gsr block.Its bored to 84.5 and im using an LS crank.
When I assembled it,I noticed they were close,but I just moved them a little bit.
I wonder if they moved or something....I get this light tapping noise under light load only.weird
wHOAlly Oct 20, 2004 05:43 PM
Re: wiseco piston hitting Oil squirter Jets (PyroProblem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">
I wonder if they moved or something....I get this light tapping noise under light load only.weird</TD></TR></TABLE>
detonation/ping?
PyroProblem Oct 20, 2004 05:58 PM
Re: wiseco piston hitting Oil squirter Jets (Sp00n'd Supra)
No not detonation,I used to get that at WOT in 4th and 5th gear until I retarded My timing almost all the way...(still saving for EMS)
It sounds more mechanical...I used to think it was just piston slap but now Im starting to wonder...
Not valve contact either.Engine was clayed for clearances...
Oops,sorry for thread jacking https://honda-tech.com/forums/images...es/emdgust.gif
wHOAlly Oct 20, 2004 06:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">I used to think it was just piston slap but now Im starting to wonder...</TD></TR></TABLE>
piston slap makes ur motor sound like a diesel
93lsd Oct 20, 2004 08:17 PM
well looks like somebody better drop the oil pan too be on the safe side, but if you have a oil guage you can see if on is broken because there will be a loss of oil pressure at wot
crucian Apr 17, 2005 07:25 AM
Re: wiseco piston hitting Oil squirter Jets (93lsd)
I know this topic is old but I have this same problem. Luckily I checked for clearance. For those who buy wiseco pistons BE AWARE of the oil jets hiting the bottom of the pistons!!!!! I have stock bore!
non-VTEC Apr 17, 2005 04:19 PM
Re: wiseco piston hitting Oil squirter Jets (crucian)
wiseco includes a warning sheet that specifically addresses that exact issue.......you guys should read all the paperwork that comes with the piston kit...... https://honda-tech.com/forums/images/smilies/emthup.gif
hondaguyef Apr 17, 2005 06:23 PM
Re: wiseco piston hitting Oil squirter Jets (non-VTEC)
For those of you that had the Squirters come out in the pan, What did you do after you found they were broken off?
crucian Apr 17, 2005 09:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">wiseco includes a warning sheet that specifically addresses that exact issue.......you guys should read all the paperwork that comes with the piston kit...... https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Damn, I knew I saw that sheet somewhere. I search all over for it but couldnt find it again and thought I was imagining things! I decided to check clearance anyways just incase I wasn't hallucinating. What exactly does the warning say again? Anyone happen to have it laying around? Thanks!
non-VTEC Apr 18, 2005 03:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crucian &raquo;</TD></TR><TR><TD CLASS="quote">
Damn, I knew I saw that sheet somewhere. I search all over for it but couldnt find it again and thought I was imagining things! I decided to check clearance anyways just incase I wasn't hallucinating. What exactly does the warning say again? Anyone happen to have it laying around? Thanks!</TD></TR></TABLE>
it says that the piston skirt will contact the oil squirter's. you need to re-adjust them and allow a minimum of .030 clearance between the skirt and the oil squirter.
crucian Apr 18, 2005 11:40 AM
Thanks bro! You're a life saver! https://honda-tech.com/forums/images/smilies/emwink.gif
dfoxengr Apr 18, 2005 12:13 PM
you can bend the squirters out of the way
hondaguyef Apr 18, 2005 03:02 PM
Re: wiseco piston hitting Oil squirter Jets (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">For those of you that had the Squirters come out in the pan, What did you do after you found they were broken off? </TD></TR></TABLE>
Anyone?
