Will this work?
Im putting my h22 in a1995 civic si .I have a typeR ecu can i use this ecu with
this setup? https://honda-tech.com/forums/images.../h-emblem4.gif |
Re: Will this work? (crx428whp)
I'm pretty sure that the H22 engine has a dual stage intake manifold the is controlled by the ECU. If you were to use the Type R ECU (If it actually works) you wouldn't be able to control the butterflies in the inatke manifold resulting in poor breathing.
| All times are GMT -8. The time now is 04:27 AM. |
