need help code 23?
1 Post
need help code 23?
it has 2 slow and 3 fast check engine light
on a obd 1 92 civic with a b-seres
can it be the Code 23 Knock Sensor ??
Re: need help code 23?
COde 23 does mean that there is a problem with the knock sensor or its input to ECM.I would start by checking that it is plugged in/ Maybe disturbed by oil change/recent work. The check that it is tight in the block. then check continuity to to the ECM connector D Pin#3. If all is good then replace the knock sensor. Good Luck and follow up.
