Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Wierd noise! (https://honda-tech.com/forums/tech-misc-15/wierd-noise-343239/)
bokguay Nov 25, 2002 11:18 AM
Wierd noise!
When i brake...there is this noise coming from the left caliper and it makes a grinding noise but only in 1 second intervals...likeit hits a certain spot on the rotor and u hear it...a shop told me it is the wheel bearings but i really dont believe it is....do u guys know what it might be?
Spade Nov 25, 2002 11:27 AM
Re: Wierd noise! (bokguay)
You check your wheel bearings by jack that side off of the ground.
Place your hands on 12 and 6 and attempt to wiggle the wheel. If it moves, inspect your ball joints on the control arms. If they are good. It's your bearings.
bokguay Nov 25, 2002 12:35 PM
Re: Wierd noise! (Spade)
i juss PM ed u
artifex Nov 25, 2002 03:11 PM
bad wheel bearings make a constant oscillating noise while at speed (40-75), at least in my experience. with an intermittent noise only under braking, i'd say your rotors are warped. mine were warped in the rear and they make a god-awful intermittent scraping noise just like what you describe. hope that helps.
Neil
[Modified by artifex, 6:12 PM 11/25/2002]
