Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   When swapping out radiators.. (https://honda-tech.com/forums/tech-misc-15/when-swapping-out-radiators-277209/)
drumsy Sep 11, 2002 03:17 PM
..is it necessary for me to drain the coolant from the engine block, via the drainage bolt? Additionaly, how do I bleed the coolant system for air bubbles?
bryant Sep 11, 2002 07:51 PM
Re: When swapping out radiators.. (drumsy)
nope wont need to drain from the block. And to make sure to get all air bubbles out just fill it up with the car running.
salbaje Sep 11, 2002 11:25 PM
when you put in the new radiator,fill up the radiator and start the car and let it idle to normal temp. then refill as it goes down and watch the airbubbles come out. then put back cap and you're good to go
drumsy Sep 12, 2002 06:46 AM
Re: When swapping out radiators.. (salbaje)
Thanks for the information! http://images.zeroforum.com/smile/emthup.gifhttp://images.zeroforum.com/smile/emsmile.gif
