Wheel sizing technical question
My CR-Z has 4 of the same size tires (195/55-16) from the factory, and it also has the same bolt pattern as a Mk2 MR2 (5x114.3), letting me have the ability to use the staggered (17x7f 17x8r) Advan wheels that I already have. I don't see a clearance issue with running a 235/40-17 on the rear, and it won't affect the speedo, since its FWD. The fronts are going to be a 215/45-17, which is close enough to the stock height/rolling diameter to make a negligible difference.
My main issue is: if i run a considerably different size than stock tire (2" wider) on the rear than stock, will I run into any braking issues or any other foreseeable issues? Hopefully what it would look like: http://i470.photobucket.com/albums/r...20CRZ/0362.jpg That huge rear fender overhang: http://i470.photobucket.com/albums/r...0CRZ/029-1.jpg How they sat on my MR2 http://i470.photobucket.com/albums/r...oy1000/mr2.jpg |
| All times are GMT -8. The time now is 12:53 AM. |
