Wheel hub removal / replacement
Im going to be removing the front wheel hubs on my 94 integra soon. They have bad studs (stripped) and the wheel bearings I believe are on their way out.
I am looking for detailed instructions or a how-to on this. More specifically, I need to know what particular tools i will need.. such as separating the knuckle from the wheel hub. and pulling and putting on the new wheel bearings. Here are the steps that I know to do: 1 remove 32mm axle spindle nuts 2 remove rotor 3 separate lower ball joint 4 press/separate the axle out of the hub 5. set the brake/caliper assembly to the side 6. what do i do from here?? tia |
Re: Wheel hub removal / replacement (tilt)
Put #5 before #2, and seperate all the ball joints then take out the knuckle and swap bearings with a press.
Re: Wheel hub removal / replacement (sackdz)
Take the knuckle out, take it to a machine shop, and have them press the old bearings out and new ones in. Removing the kunckle simply involves separating the balljoints, tie-rod ends, and the caliper/rotor. Don't even waste your time trying to do the bearings yourself (unless you have a press).
Re: Wheel hub removal / replacement (Aron Parsons)
Take the knuckle out, take it to a machine shop, and have them press the old bearings out and new ones in. Removing the kunckle simply involves separating the balljoints, tie-rod ends, and the caliper/rotor. Don't even waste your time trying to do the bearings yourself (unless you have a press). |
Re: Wheel hub removal / replacement (UnderFire)
How hard is it to separate the tie-rod ends? do you need a special tool for it?
I have a whole new pair of wheel hubs with new wheel studs already pressed in, I just need to get the wheel bearings on the new hubs... do i need to get those pressed on as well? Im not sure how the knuckle attaches to wheel hub... can someone explain this part? |
How hard is it to separate the tie-rod ends? do you need a special tool for it? |
Re: Wheel hub removal / replacement (CXHatchback)
Nope, remove the castle nut, then hit it with a sledge hammer from the bottom on the stud. Or use a separating fork, but that will tear your boots. Or, buy the $20 tool to remove them, but it's so much qquicker and easier to just hit it from the bottom. |
| All times are GMT -8. The time now is 08:54 PM. |
