What is O-ring a block?
I want to know what is O-ring a block? If you have some picture it will be very well https://honda-tech.com/forums/images/smilies/emthup.gif
Help please
Re: (Garrett)
I search and found about 300 topic and don't see what is O rings
Re: (Garrett)
Bringing this post back from the dead. I also want to know what is o-ringing ? And when is it necessary ?
it is not necessary, an O-ring goes on top of a sleeve to help the headgasket to have a better seal, i have found that using the step deck option is alot better and consitent
Re: (PrettyLude)
I didn't really know that O-rings were used on Honda engines due to the open deck configuration, but is common on high compression domestic engines.
What happens is that there is a circular groove cut in the block's deck surface around the cylinder (the head surface). Then a copper (I believe) o-ring is set in in the groove (between the block and head gasket). This ring helps keep the compression from blowing out the head gasket. If you want more information, you may ge better off searching through Domestic car web sites. You could try Chevelles.com Wes |
| All times are GMT -8. The time now is 09:25 AM. |
