Yet another ECU question
Old 10-12-2015, 06:03 PM
schuttman's Avatar
Icon4 Yet another ECU question
2002 Civic EX bought used. Drove car two weeks and realized hack mechanic that worked on car prior to purchase stripped out alternator bracket and fried ECU. This is a California low emission car. Put first ECU box in and would not work. Realized replacement box came from federal emissions car. Researched and found used ECU box with numbers 37820-PLM-L54 pulled out of California car also. The replacement box number matches original box number. Replacement box will not start car. Does anyone have any ideas or come someone help me please!
Old 10-12-2015, 06:45 PM
RTFM
v4lu3s's Avatar
Default Re: Yet another ECU question
What about the immobilizer?
Old 10-12-2015, 06:47 PM
JRCivic1's Avatar
The immobilizer indicator should be illuminated on the dash "green key" when you try and start the car. You must have the key, immobilizer and ECU married by either your local Honda dealership or an advanced service technician with the proper equipment.
Old 10-12-2015, 07:36 PM
schuttman's Avatar
Ok sorry to sound stupid but where is the immobilize? I do not know much about the computer and electronics on these cars, I can pretty much do anything else.
Thanks
Old 10-12-2015, 08:24 PM
holmesnmanny's Avatar
It's likely you have a blown fuse, probably the main big alternator fuse going through the engine fuse box, among possibly other fuses.
Old 10-12-2015, 08:56 PM
schuttman's Avatar
Thanks I will check that
Old 10-13-2015, 05:03 AM
RTFM
v4lu3s's Avatar
The immobilizer is in the computer in the key and in the ignition switch all three must be coded together to work correctly together or the car will never start
schuttman
Honda Civic (2001 - 2005)
10-26-2015 05:39 PM
CiViC SiR
05-18-2004 03:26 AM
H22CL
01-12-2004 04:12 PM
ElectronMan
07-15-2002 02:02 PM
Quick Reply: Yet another ECU question
