Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   what else to do for the motor (https://honda-tech.com/forums/tech-misc-15/what-else-do-motor-413554/)
juicedricer Feb 12, 2003 08:34 AM
my fren n i are doing my swap this sat n sun night but until then im replacing the header gasket, water pump, timing belt and cam seals and my clutch on my b18b anything else u guys suggest to do??? i was thinking about the oil pump but shit man i am flat broke. just buying misc parts n everything else. also i have a gsr throttle body, should i put that on too because i looked at it and it looks a little bit larger, but i really dunt kno if it will make any difference. hopefully by mon afternoon/night it will be all in done...*whew*
civic97dx Feb 12, 2003 08:40 AM
Re: what else to do for the motor (juicedricer)
i did plugs, cap, wires, and rotor before i installed my swap. it's a few more dollars but can help to elminate problems you may have later. also allow more time than what you plan, something always goes wrong when you rush.
Stroker Feb 12, 2003 01:34 PM
Do the oil pump, mine just went out and ive only had my swap in for about 6 months, that leads to another T belt. Just my 2 cent
