What else can I block?
This is an H22 Intake Manifold.
Which vacuum lines are OK to block off? Can anyone draw arrows pointing to what lines are ok to block off or re-direct? As you can see below, I am blocking that line with a screw. Where can I get the REAL "blockers"? http://ophdeheezy.webspacesales.com/vac.jpg And what do I do with this? An aftermarket intake doesnt have a place to put this like the stock one does. http://ophdeheezy.webspacesales.com/vac1.jpg |
Re: What else can I block? (ophdeheezy)
The pics aren't showing... https://honda-tech.com/forums/images...s/emhammer.gif
Re: What else can I block? (GTlvr82)
pics are fine
bump for night crew |
Holy vacuum-lines batman!!! https://honda-tech.com/forums/images...s/emsmileo.gif
[Modified by GM2000ITR, 6:30 AM 3/26/2003] |
Re: What else can I block? (GM2000ITR)
Never block line 21. It goes to you MAP sensor. Mike
| All times are GMT -8. The time now is 03:31 PM. |
