Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   what is B18 and B20 diffrences? (https://honda-tech.com/forums/tech-misc-15/what-b18-b20-diffrences-2595842/)
hondajav06 Jun 25, 2009 11:20 AM
can any one tell me what is the diffrences between a b18 and a b20? I am trying to swap my b20 in my crv for a b18
angel_i Jun 25, 2009 11:12 PM
Re: what is B18 and B20 diffrences?
I think they are different in the intake manifold and the B20 has a bigger bore. The Jdm P8R has a better flowing head also.There are more differences 2.
Spoon84 Jun 26, 2009 09:38 AM
Different Intake manifold. You'll need to your LS intake manifold. The head is somewhat the same... but some say it flows better. Also the block is 84mm compared to 81mm LS. The compression is pretty much the same. The factory B20 Oil pump produces more better oil pressure than say a 95 and below LS motor. That pretty much it.
But the block swap is diffenelty worth it. More low end torque. If you decided to put a vtec on it later on. The b20/vtec motor with high compression pistons and depending on other stuff you upgrade could yield between 200+230 hp.
kyden Jun 26, 2009 10:10 AM
which b18?
