Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   what is this? (https://honda-tech.com/forums/tech-misc-15/what-1967178/)
wmertz187 Apr 27, 2007 01:06 PM
what is this?
i was tranfering pumps and sensors from my type-r block to my b16 block and found this on the type-r
https://img234.imageshack.us/img234/...ture001yz6.jpg
The b16 does not have that
Then the oil filter adapter has a hose running to this part that was bolted into the block
https://img236.imageshack.us/img236/...ture004vy9.jpg
and on the b16 theres just a bolt there.
Is this a type-r upgrade?
JimBlake Apr 27, 2007 03:38 PM
Re: what is this? (wmertz187)
It's an oil cooler. Look at the hoses # 2 & 3. The cooler itself isn't numbered in this picture. One of the hose nozzles in the block is #1 - that's what you have. You may need to use the water pipe off the type-R because of number of hose connections.
http://www.acuraautomotiveparts.org/...st70_e1513.gif
wmertz187 Apr 27, 2007 05:58 PM
and to put the oil cooler on the b16 i would need to install this
https://img209.imageshack.us/img209/...ture003du6.jpg
Its the screw for the oil filter, so ofcoarse i would have to remove the one out of the b16..
Can i do that?
JimBlake Apr 27, 2007 07:40 PM
The one in your B16 should be almost like a simple pipe nipple. I think you can just take that out & replace it with that extended one in your picture. Someone verify that for sure?
wmertz187 Apr 28, 2007 10:56 AM
Re: what is this? (JimBlake)
ya its like a lil nipple, just threads.. how is this removed
mitsuman Apr 28, 2007 03:02 PM
i had nothing else so i clamped it down with vice grips and twisted it slwoly
inspyral Apr 28, 2007 07:42 PM
You can use a strap wrench if you don't want to damage the threads.
wmertz187 Apr 29, 2007 12:52 PM
Re: (inspyral)
thanks for input guys https://honda-tech.com/forums/images/smilies/emthup.gif
