Warning light advice - Honda-Tech - Honda Forum Discussion
Old 01-08-2019, 07:56 AM
Default Warning light advice
A warning light has appeared on my dashboard (an orange engine-shaped light), which according to the manual means that the "engine's emissions control systems may have a problem". What is likely to be causing this? The car (Civic) had a new exhaust & catalytic converter fitted only a few months ago.
The day before this light came on I had a new battery fitted, and I am wondering if this could somehow be causing the problem - dodgy connection?
RegX is offline
Old 01-08-2019, 08:31 AM
DCFIVER's Avatar
Default Re: Warning light advice
You want us to guess? There are literally hundreds of reasons why it could be on
Geez guy its 2019. No one should be this ignorant on any subject with the internet around.
Have the code scanned.....
DCFIVER is offline
Old 01-08-2019, 09:01 AM
No, I would like to hear from anyone else who has had the problem.
Absolutely. That's why I am using the internet to ask the question.
Not sure what you mean by this, but I suspect you are referring to more modern models. There is no code, just a light.
RegX is offline
Old 01-08-2019, 07:14 PM
DaX
DaX's Avatar
What year is the Civic? Searche how to pull CEL (check engine light) codes for the generation (year) of civic you have. There is a code (or codes) stored in the ECU if the CEL is on.
DaX is online now
Old 01-08-2019, 08:54 PM
muellersfan's Avatar
Also, what modifications?
muellersfan is offline
Old 01-09-2019, 08:29 AM
I like the tuna here
DumpdEJ6's Avatar
"Check engine light is on, has this happened to anyone else?"
........um....yeah. Probably a few people.
DumpdEJ6 is offline
Old 01-09-2019, 08:36 AM
Thanks, that has pointed me in the right direction. Such is my lack of knowledge that I didn't even know of the existence of the ECU, let alone what it was. But as DCFIVER so helpfully observed, thanks to the wonders of the internet no-one needs to remain in ignorance!
RegX is offline
Old 01-09-2019, 02:13 PM
Moderator
TheShodan's Avatar
this forum isn't the best place to look. You need to try some video guidance. Eric the Car Guy on YouTube is a great place to start when it comes to mechanics basics.
TheShodan is offline
Old 01-09-2019, 09:47 PM
After 1996, Due to On Board Diagnostics 2 (OBD II).
The orange engine shaped light is the "Check Engine Light" (CEL).
It indicates that something has gone wrong.
There are a bunch of sensors that feed information to the ECU (engine control unit)/ ECM (engine control module).
When one of those sensors feed information that do not fall within certain pre-programmed parameters, it stores a code.
If the failure repeats then the repeated code forces a CEL or mal-function light to go on.
If the failure is severe then it will flash the CEL to indicate that engine damage can happen very soon.
When there is a CEL, a code reader or scanner can communicate with the ECU and pull the codes out.
That code relates to the type of failure. It may be related to certain parts.
It doesn't mean the part is necessarily bad and needs to be replaced.
It does indicate where to start troubleshooting the issue.
Codes can be looked up on the internet.
Many youtube videos available on how to work on cars/engines.
Good luck
avisitor is offline
Old 01-12-2019, 05:35 AM
tony_2018's Avatar
Throw a pokeball at it
When a cel like comes on you check the ecu for codes and diagnose the issue. You'll then either repair or replace the failed/defective/damage/fucked up part
​​​​​​​Check cel code yet?
tony_2018 is offline
Old 01-12-2019, 03:27 PM
Moderator
TheShodan's Avatar
Yeah, I think that this thread is done. Now it's all about the jokes
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
