Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Valve cover filter purpose? (https://honda-tech.com/forums/tech-misc-15/valve-cover-filter-purpose-2295086/)
fryman May 8, 2008 03:00 AM
I've seen many racers and tuners that have a small filter on the valve cover instead of having the tube that goes to the air intake.I was wondering whats the purpose for doing that?
http://images.hondatuningmagazine.co...her_filter.jpg
mmuller May 8, 2008 04:04 AM
Re: Valve cover filter purpose? (fryman)
it does nothing, no pros some cons
GhostAccord May 8, 2008 04:21 AM
Re: Valve cover filter purpose? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fryman &raquo;</TD></TR><TR><TD CLASS="quote">a small filter on the valve cover instead of having the tube that goes to the air intake.</TD></TR></TABLE>
Doesn't do anything more than what you just mentioned. It allows people to run intakes without the VC breather hose. Some after market intakes do not have the fitting for a valve cover breather hose. Or if your running a Turbo you wouldn't usually want too many holes in the intake piping.
fryman May 8, 2008 04:22 AM
What are the cons?Why do people do it if it has no purpose?
GhostAccord May 8, 2008 04:25 AM
It does have a purpose, it allows you to maintain the proper fresh air intake for the PVC system. There are no mechanical Pros or cons the only real pro is that it gets rid of one more hose in the engine bay.
fryman May 8, 2008 04:29 AM
Re: Valve cover filter purpose? (GhostAccord)
Oh ok.Didn't see your previous post.Ok now I understand.thanks
rudebwoy May 14, 2008 06:31 PM
I would say their is a pro.
I run a breather can off the valve cover and also the little filter, lets the engine breathe better instead of having it teed into the catch can, or intake.
Bakeoff May 15, 2008 12:39 PM
wow...
The pcv system will suck oil vaport back in through the intake. This can gum up the TB, and coat your intake manifold if you're getting a bunch of blow by. Sucking it back into the cylinders makes for a cleaner burning engine, but if you're getting a lot of blow by, you may not know it, and you're running a higher risk of detonation because of the oil. The cons of running a filter? A dirty spot on the bottom of your hood.
firmk20 Mar 28, 2013 07:38 AM
Originally Posted by Bakeoff (Post 33874945)
wow...
So r u saying its better to run the little filter on the valve cover?
1998GsRIntegra Mar 28, 2013 06:52 PM
wow...
If you're getting enough blow by from the tiny factory port on the valve cover to foul the combustion mixture, your engine is fucked anyway. If your engine is healthy, there is zero problem with hooking the pcv system up how it was designed to be hooked up by the engineers at honda. Unless you are forced induction, then we are talking about different circumstances.
And wow, old thread.
d_moua Apr 2, 2013 07:23 PM
there for fresh air into pvc
rudebwoy Apr 3, 2013 04:12 AM
wow thats a old thread! now that I've been through so many setups since then. Pros would be breathe better, and keep blowby out your intake, Cons would be a messy ingine bay. in the end it is better to get a breather can.
