Value of This Longblock.
Hey guys i'm trying to see what my motor is worth in value. I may be selling it to pay some bills I want it to be far but still good value for me. If this is the wrong fourm i'm sorry for the inconvenience. Thanks for your time guys.
NO SMOKE GREAT COMPRESSION (9:8:1) with the block and head combination good T-belt/Water pump good plugs/wires New intake/TB gasket good cap/rotor USDM B18C1 block JDM b16a1 head NEW blox intake manifold NEW 65mm TB GSR cams AEBS head studs OEM headgasket OEM ITR oil pump stock flywheel ACT pressure plate stock disc. full mounts shift linkage and inter. shaft with axles. No exhaust manifold No tranny No wiring harness Pretty much just need the above listed and it will fire right up I GUARANTEE it will fire and run with out any problems on the motors part that is Thanks again guys i can get pics and awnser any questions. Kevron Modified by KevronsEG at 2:05 PM 2/11/2007 Modified by KevronsEG at 6:31 PM 2/11/2007 |
| All times are GMT -8. The time now is 05:18 AM. |
