Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   VAFC Bad??? (https://honda-tech.com/forums/tech-misc-15/vafc-bad-1154279/)
93gsrcoupe Feb 18, 2005 06:01 PM
VAFC Bad???
Has anyone ever had a VAFC that didn't work? I just installed a used one and the vtec won't engage. I have a chipped p28 which usually set off vtec at 5600, but now nothing happens. The VAFC says that vtec is on, but nothing happens. I had this installed at a shop, and everything works except this. What could be wrong?
Vtec92Civic Feb 26, 2005 02:10 PM
Re: VAFC Bad??? (93gsrcoupe)
could simply be that they hooked it up wrong. I mean its always a possibility. Just don't overlook anything. Check the wiring, check your vtec oil pressure switch, check your ecu just double check it all and make sure that you have the settings correct on your vafc. https://honda-tech.com/forums/images/smilies/emthup.gif
zman Feb 26, 2005 03:22 PM
Re: VAFC Bad??? (Vtec92Civic)
check to see in the settings what the V/T CONT says for L->H and H->L. If it says **** then there are no changes made by the vafc.
Or maybe the purple wire or pink wire from the vafc is not connected properly to your cars wiring harness, also check the yellow wire and white wire
