Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   uneven drops (https://honda-tech.com/forums/tech-misc-15/uneven-drops-200190/)
redteg1 Jun 3, 2002 04:32 PM
uneven drops
i have eibach prokit on my gsr and i just noticed today that the driver side front is a bit lower than the passenger side and the passenger side rear is slightly lower than the rear driver side...wat is this from?! could this be normal? wat could've caused t his?
redteg1 Jun 3, 2002 05:58 PM
Re: uneven drops (redteg1)
ttt
dkay040 Jun 3, 2002 06:14 PM
how are ur shocks doing??
redteg1 Jun 3, 2002 06:17 PM
Re: uneven drops (dkay040)
stock shocks on 1.5 in drop ...eibach prokit...have had them on for a while now but they're kinda sqeaky creaky over bumps
dkay040 Jun 3, 2002 06:23 PM
maby there blown thats the only thing i can think of
allmtr Jun 3, 2002 08:20 PM
have you gained any weight lately?
redteg1 Jun 4, 2002 02:37 PM
Re: uneven drops (allmtr)
yea 230lbs in 1 yr http://images.zeroforum.com/smile/emsmilep.gif
wuggiewuggie Jun 4, 2002 05:52 PM
dood!!! i have the same freaking problem with my integ... i thought i put my car back together wrong or sumtin... the passenger rear wheel sits higher than the driver side rear wheel by like a cm or maybe a lil more. I just started noticing it. Now that you guys mentioned it i think my stock shocks are probably blown to hell and that mite be what's causing my problem. Haha... i've been driving my car slammed like 3.5 inches (lowest setting on the coilovers) for like 6k miles.
khoalie Jun 4, 2002 08:23 PM
Re: uneven drops (wuggiewuggie)
its probably caused by the fact that you usually drive alone in the car
the extra weight actually does make the driver side sag some.
my friends integra did this so we ended up just swapping the springs from one side to the other.
that way the other spring can 'sag' and they would eventually become even
my car did this too but all i had to do was crank the coilover up a little
redteg1 Jun 4, 2002 08:31 PM
Re: uneven drops (khoalie)
well i don't have coilovers...bah http://images.zeroforum.com/smile/emexclaim.gif
dLo GSR-stolen-now-WRX Jun 5, 2002 12:19 AM
cars are not evenly balanced in weight, even w/out driver. adjust accordingly.
khoalie Jun 5, 2002 05:18 PM
http://images.zeroforum.com/smile/emhammer.gif http://images.zeroforum.com/smile/emhammer.gif
tonydatyga Jun 12, 2002 02:48 PM
eww
