Turbo
I just got a Garrett t3/t4 turbo in my 00 Civic SI. The motor is all stock with only cam gears and a skunk2 intake manifold. Does anyone know how long my motor will last before I have to rebuild it if I just boost 8lb the most and racing it once in a while.?
Re: Turbo (JDMSI)
you'll be fine, just dont push to much more than that
Re: Turbo (Acura_I-RS)
the better your fuel control, the longer your engine will last
Re: Turbo (22lbGS-R)
Haw reliable will it be
Re: Turbo (JDMSI)
Haw reliable will it be If you keep great care of it, you should be fine at 9psi. But don't forget you'll have to change the oil much more, new plugs all the time, wires, etc. Be nice to it and it'll be as reliable as you need it to be. https://honda-tech.com/forums/images/smilies/emthup.gif |
| All times are GMT -8. The time now is 05:44 AM. |
