Tuning..
if i set the cam gears on +4 in. and -2ex. what should i set my timing on...16 degree or 0 degreee.. https://honda-tech.com/forums/images...s/emsmileo.gif
Re: Tuning.. (m2slsvtec)
you set it just like you normally would
Re: Tuning.. (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">you set it just like you normally would</TD></TR></TABLE>
so that means if i mess around with the cam gears i have to set it to 16 btc? |
yes everytime u change the intake camgear timing will change so u have to reset it to
Re: (rev-speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed »</TD></TR><TR><TD CLASS="quote">yes everytime u change the intake camgear timing will change so u have to reset it to
</TD></TR></TABLE> so reset it to 0 degree or 16 degree??? |
Re: (m2slsvtec)
Uhh.. You set your timing back to stock which is 16 degrees BTDC.. If you dont know what to set it to then you shouldnt be messing with it..
And why those cam gear settings, did you hear that from someone else or something? |
| All times are GMT -8. The time now is 05:30 AM. |
