Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   TRX450R (https://honda-tech.com/forums/tech-misc-15/trx450r-3029084/)
riverrunner06 Feb 19, 2012 07:46 PM
TRX450R
I know this is likely out of the norm here. I would like to ask if anyone has dealt or has knowledge of the matter. I have an '04 TRX450R that the idle will not remain stable. I adjust the set screw to a desirable idle speed. then after riding a short while it will either be too high or stalls. After adjusting again I get the opposite reaction. I have cleaned the carb 4 times and nothing has been found in the float bowl the last 3 times. There is a throttle position sensor on the carb. Last summer I found that if it was disconnected the idle stablized and I did not have a problem until the weather turned cold. The bike runs great, just the idle is not stable. Any suggestions would be welcomed.
thx
Dc4LsTeG Feb 19, 2012 07:48 PM
Re: TRX450R
There's a motorcycle section here. Try there
riverrunner06 Jan 30, 2014 09:38 AM
Re: TRX450R
I have dealt with this. I found the throttle position sensor was the issue. I disconnected it and got much better stability on idle. Of course replacement is the best solution. The TPS is a pricey part though.
schneedrache Jan 31, 2014 05:31 PM
Re: TRX450R
Holy thread bump batman.
riverrunner06 Jan 31, 2014 09:21 PM
Re: TRX450R
LMFAO!!! I replied from my android and didn't realize that I posted this originaly... :o)
