Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Transmission question (https://honda-tech.com/forums/tech-misc-15/transmission-question-789851/)
AsianMullet Mar 5, 2004 08:27 PM
I recently just got my clutch installed on my gsr. Didnt ask if he filled the transmission fluid but it keeps popping out of 5th gear on the highway....could low transmission fluid be the problem?? how many quarts to fill the tranny anyways? Thanks for your help.
Kendall Mar 5, 2004 09:01 PM
I wouldn't rule it out, but it shouldn't pop out due to lack of tranny fluid. Of course you can always check your tranny fluid and find out if that's the problem.
InjectedPerformance Mar 6, 2004 12:04 AM
Re: Transmission question (EKchump)
Yes! It is lack of oil in the tranny!
acy76 Mar 6, 2004 09:24 AM
Re: Transmission question (primo8998)
Low fluid can cause this problem.
2kstreetcivic Mar 6, 2004 10:40 AM
Re: Transmission question (acy76)
yes, you could have low fluids...just check them and you should be fine
trialoner Mar 11, 2004 12:01 AM
Re: Transmission question (2kstreetcivic)
I wish I would of known to check my tranny fluid when my car jumped out of gear... Now my tranny is toast... But, b16a1 tranny on the way for my b18!!
yay... https://honda-tech.com/forums/images/smilies/emthup.gif
turbodGSR Mar 11, 2004 08:32 AM
Re: Transmission question (trialoner)
i dont think low fluid would cause that, sounds like the ring on the fifth gear blocking ring is toast.
deepbluepentium Mar 31, 2004 03:23 PM
I could be several things. First of all b series trannys dont use transmission fluid. You would have to use 10w-30 (the same as your motor). If it pops out on the freeway and its not an oil factor it can be one of your synchronizers. If later on 4rth gear is giving you problems then its your synchros. If you lack oil or the right oil then you probably just wore out your 5th gear and it will need replacing. Check your oil if you change it on your tranny and look for metal flake (tiny chunks of metal). Or could be your housing. Ive had just about every problem with honda trannies so just keep in touch and let me know what else you find wrong. Oh yeah one more thing if you took your car to get a clutch then the mechanic would have to been really really forgetful to forget to put oil in your tranny.https://honda-tech.com/forums/images/smilies/emthup.gif
InjectedPerformance Mar 31, 2004 03:49 PM
Re: Transmission question (deepbluepentium)
it is deff. Low on tranny oil!
AsianMullet Mar 31, 2004 04:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primo8998 &raquo;</TD></TR><TR><TD CLASS="quote">it is deff. Low on tranny oil!</TD></TR></TABLE>
Yup...tranny oil was dry......pennzoil syncromesh works good https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif !
Mr Boston Mar 31, 2004 05:10 PM
Good thing u noticed it https://honda-tech.com/forums/images...es/emsmile.gif
