Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Transmission question (https://honda-tech.com/forums/tech-misc-15/transmission-question-2897541/)
b00stedOne Feb 13, 2011 04:38 AM
Hey. This is my first time opening up a tranny myself. Its and LS hydro tranny and I am installing an mfactory lsd. My question is, can I use the ring gear (i think its called a ring gear. the big gear that bolds to the diff) from and sir instead of the ls to get a little shorter gearing? I already have the ring gear, but do i have to swap out anything else to make it work?
Thanks in advance.
b00stedOne Feb 13, 2011 07:58 AM
Re: Transmission question
anyone?
i updated the info to try to explain a bit better
Metrospeed Feb 13, 2011 08:09 AM
Thanks in advance.
You will have to swap out the counter shaft with the ring gear.
b00stedOne Feb 13, 2011 08:14 AM
ok thanks man. in that case, i guess i wont be using the sir one because i dont have the counter shaft.
