tps
i just put a new TPS on my car, now my car sounds funny as shit.. and my timing belt seems like it is a little looser than it was.. wtf could of caused this? when the tps broke it blew the intake off of the throttle body and also literally broke the TPS into 2.
Re: tps (iHOPEyouCHOKE)
if the timing belt is getting looser then its most likely the tensioner. grab a new
belt and tensioner from the honda dealership and all will be cured. and just to warn you. GO WITH A OEM tensioner. the oem equivalents at the auto parts stores tend go bad really quick sometimes. i've heard this from many people lately, and the last thing you want is to lose your belt on the highway goin 70. just a lil advice, hope this helps. repost and lemme know. |
Re: tps (hondaxsimike)
Did you set the tps when you installed it? if not then it would cause your car to run like crap
Re: tps (Xsi)
How do you set the TPS?
Re: (Xsi)
Thanks Xsi that's really helpful but my tps seems to be about right .3X closed 4.5 open and idle is perfect guess my emission problems are somewhere else!
| All times are GMT -8. The time now is 05:18 AM. |
