Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   tools needed for extended wheel studs? (https://honda-tech.com/forums/tech-misc-15/tools-needed-extended-wheel-studs-776748/)
vtekthis Feb 23, 2004 03:29 AM
can somebody tell me what tools im going to need to tackle my next job? im doing extended wheel studs on my 99 civc ex coupe and just wanted to know before i start. i heard you need a press? is this true? also please tell me if this if more of a DIY job or should i wait till i have a good amount of time so i can get to a press? any help?
thanks https://honda-tech.com/forums/images...es/emsmile.gif
vtekthis Feb 23, 2004 03:56 AM
Re: tools needed for extended wheel studs? (vtekthis)
anyone know??? https://honda-tech.com/forums/images...s/emsmilep.gif
doublejz Feb 23, 2004 06:34 AM
you will need a press. your gonna have to press the hub apart to remove the wheel studs. Sometimes you even need the press to push the studs out, or you can beat them https://honda-tech.com/forums/images...s/emsmilep.gif To put them in, I usually just put the studs in, oil them a little, put some washers on it and crank them tight with a lug nut to pull them the whole way. Then put the hub part together
vtekthis Feb 23, 2004 07:14 AM
ok, thanks, so its not a job to do without a little time and a press.
dfoxengr Feb 23, 2004 07:42 AM
Re: (vtekthis)
you dont HAVE to havea press. use a sledge, and then bring the new ones on with lug nuts and an impact
doublejz Feb 23, 2004 01:07 PM
Re: (hybridvteceg)
i dunno about you, but last time i changed mine, i needed to take the hub apart which i needed a press to do. http://images.honda-tech.com/set1//smile/emcrook.gif
slixxracing Feb 23, 2004 01:25 PM
Re: (doublejz)
you dont necessarily need a press to get the job done, but it will make it hell of alot easier w/ one. by the time you're hammering away the hub to knock it off you'll be saving yourself alot of time just having it pressed out. took me about 1hr before hammering my hub in. once i got it done, it was all screwed up...had to buy new ones and replace them again. but the second time, i paid a shop to press it in for me.
RCautoworks Feb 23, 2004 03:12 PM
Re: (slixxracing)
You do not need a press, you need air tools and a slide hammer.
fullracegsr Feb 23, 2004 06:46 PM
Re: (90blackcrx)
all you really need is a slide hammer... air tools help but are not a must...
slammed_93_hatch Feb 23, 2004 08:08 PM
Re: (fullracegsr)
saying you don't need a press is like saying
you don't need a hoist to do a swap
dfoxengr Feb 23, 2004 08:09 PM
Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">saying you don't need a press is like saying
you don't need a hoist to do a swap</TD></TR></TABLE>
you dont need a hoist to do a swap.
think lift the car over the engine. lol. bad simile.
slammed_93_hatch Feb 23, 2004 08:19 PM
Re: (hybridvteceg)
wow you obviously didn't get my post.
dfoxengr Feb 23, 2004 08:21 PM
i thought u meant you have to have a press. be clearer, lol
slammed_93_hatch Feb 24, 2004 02:29 AM
Re: (hybridvteceg)
i was being sarcastic.
just use the press itll be alot easier
dumppp gook Mar 15, 2004 10:53 AM
what is the press called? i need it... i dont know how to get my damn studs out cuz thers something blocking it from the back....what do i doooooo!!!! https://honda-tech.com/forums/images...s/emsmilep.gif
dfoxengr Mar 15, 2004 10:54 AM
Re: (integrallmotor)
its a shop press. but you can implement a slide ammer, or an air impact gun
