Timing belt problem
Ok i tighten my timing belt and it is tight on the front side. The side that goes around the tensioner and water pump it is not as tight as the front. I can wiggle it just a little. Does that side have to be tight also liek the first one i described??
Re: Timing belt problem (redturbocivic)
someone out there
I am using a gsr timing belt, with gsr water pump,gsr oil pump on a 96 ls block.
| All times are GMT -8. The time now is 07:20 AM. |
