Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Timing Belt BS (https://honda-tech.com/forums/tech-misc-15/timing-belt-bs-3369097/)
Fast510 Apr 5, 2023 12:12 PM
Timing Belt BS
Timing was way off on my first gen Integra. Cams matched but at #1 TDC the crank mark wasn't even close and the belt was loose.
I slipped the belt off the cam gears without having to loosen the tensioner, rotated the crank so that it was set correctly, and now the tensioner is tight and I don't have enough slack to slip the belt back over the cam gears.
I popped the plug and loosened the tensioner bolt to try and push it back down to get the belt on and I either dont have enough leverage or ... I have no idea.
How tf do I get the belt back on without having to remove the crank pulley and lower side cover because that sounds like a ton of bs.
