Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Theroetically speaking.. (https://honda-tech.com/forums/tech-misc-15/theroetically-speaking-1742032/)
Boostage Sep 4, 2006 10:12 AM
An oem oil pump on a b16 at 10,000-10,500 RPM is being stressed less than say a gsr at the same rpm right? I figure the b16 is a shorter stroke motor and has less vibrations. drastically reducing the chance of failure compared to the 1.8's
As far as I know, harmonic resonance is what destroys oil pump gears. so wouldnt a properly dampned b16 be able to see those rpms frequently without failure?
Lsos Sep 4, 2006 01:26 PM
Re: Theroetically speaking.. (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">An oem oil pump on a b16 at 10,000-10,500 RPM is being stressed less than say a gsr at the same rpm right? I figure the b16 is a shorter stroke motor and has less vibrations. drastically reducing the chance of failure compared to the 1.8's
As far as I know, harmonic resonance is what destroys oil pump gears. so wouldnt a properly dampned b16 be able to see those rpms frequently without failure?</TD></TR></TABLE>
Stresses in a rotating part rise exponentially with rpms. It has a limit whether it vibrates or not, although I have no idea what that limit is.
schardbody Sep 4, 2006 04:27 PM
GOT YOU ON AIM. hope i helped.
OBRJosh Sep 4, 2006 04:50 PM
Re: (schardbody)
Theroetically speaking.. If we went by the books then 8300rpm should break oil pumps cause thats the limit honda put on there motor, screw that shit go by what people have allready done not by what a book or some mathimatics. when it doubt REv It OUT
Modified by OBRJosh at 6:39 PM 9/4/2006
schardbody Sep 4, 2006 06:16 PM
Re: (OBRJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBRJosh &raquo;</TD></TR><TR><TD CLASS="quote"> Theroetically speaking.. If we went by the books then 8300rpm should break oil pumps cause thats the limit honda put on there motor, screw that shit go by what people have allready done not by what a book or some mathimatics. when it doubt REv It OUT
Modified by OBRJosh at 6:39 PM 9/4/2006</TD></TR></TABLE>
yeah, umm, good point *rolls eyes* BUILT BEING THE KEY WORD. his question is will a built B16 that is capable of revving to 10k not tear up the oil pump.
the question was answered already via AIM, but more insight wont hurt.
OBRJosh Sep 4, 2006 06:27 PM
Re: (schardbody)
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Modified by OBRJosh at 7:42 PM 9/4/2006
