Are there any particular sensors in an 05 Civic that tend to fail first?
I accidentally broke the original MAP sensor on my 2005 Civic VTEC while unplugging it, it must have been brittle from being old. The car seems to be running fine before I broke it, but once I installed a new OEM MAP sensor, the car ran better than it has in a long time. The engine felt much more responsive and took much less throttle than before to move the car. I think that the sensor was worn out for a while, but just didn't completely fail. Now I wonder which other sensors may be worn out. All the sensors are original with 231,000 miles on them, so they may be worn out. Which sensors wear out over time? Do cam/crank sensors and temp sensors wear out over time too? Thanks.
re: Are there any particular sensors in an 05 Civic that tend to fail first?
Inquisitive feller.
They all do. Anything with voltage and current running through them/actuating them,will wear out.
The "when" is the big mystery,for now.
(Although there is technology being developed right now for "predictive failure analysis" Basically means the ECM will alert you when your sensor/component is nearing the end of its useful life)
You can be proactive by replacing most major sensors, provided you plan on having the car for a while, and since the old ones are still working, you have working spares now. One of the good things about swapping in used low mileage jdm engines is that you a bunch of spare parts afterwards.
