Terminal Sizes on 07XMJ-001000A pin fit tool
This tool apparently is on backorder and the photos I saw on ebay showed only 5 looped wires with one that had no terminal on it. That being said, it appears as if there are only 4 looped wires that have terminals on them. Is this accurate? I can tell that one of the terminals is .64mm square, the other is .8mm X 6.4mm (the brass colored one) I'm not sure what the other 2 terminals are. I'm assuming that one of them is a .8mm X 2.8mm terminal because that is used worldwide in the lighting industry. Anyone know what sixe the other terminal is. Do you have one of these and a digital caliper to measure the terminals on the tool and verify the looped wire count? Thanks.
8dxhatchy8
22
11-01-2009 12:25 AM
